Retrieve a collection of event destinations
Retrieves information about event destinations, helping you manage and monitor event notifications effectively.
HTTP method and endpoint
GET /support/ems/destinations
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of event destinations.
Related ONTAP commands
event notification destination show -
event notification show
type |
string |
query |
False |
Filter by type |
filters.name |
string |
query |
False |
Filter by filters.name |
destination |
string |
query |
False |
Filter by destination |
certificate.ca |
string |
query |
False |
Filter by certificate.ca |
certificate.serial_number |
string |
query |
False |
Filter by certificate.serial_number |
system_defined |
boolean |
query |
False |
Filter by system_defined
name |
string |
query |
False |
Filter by name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 3,
"records": [
"certificate": {
"ca": "VeriSign",
"serial_number": "1234567890"
"destination": "administrator@mycompany.com",
"filters": [
"name": "important-events"
"name": "Admin_Email",
"system_defined": 1,
"type": "email"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
certificate
Certificate information is valid for the "rest_api" type.
ca |
string |
Client certificate issuing CA |
serial_number |
string |
Client certificate serial number |
filters
_links |
name |
string |
records
_links |
certificate |
Certificate information is valid for the "rest_api" type. |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
Destination name. Valid in POST. |
system_defined |
boolean |
Flag indicating system-defined destinations. |
type |
string |
Type of destination. Valid in POST. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
