REST API reference
Retrieve a collection of event destinations
Retrieves a collection of event destinations to manage and monitor where event notifications are sent within your ONTAP environment.
HTTP method and endpoint
GET /support/ems/destinations
Introduced in
ONTAP 9.6
  • event notification destination show
  • event notification show
name
string
query
False
Filter by name
system_defined
boolean
query
False
Filter by system_defined
  • Introduced in: 9.10
filters.name
string
query
False
Filter by filters.name
syslog.format.message
string
query
False
Filter by syslog.format.message
  • Introduced in: 9.12
syslog.format.hostname_override
string
query
False
Filter by syslog.format.hostname_override
syslog.format.timestamp_override
string
query
False
Filter by syslog.format.timestamp_override
syslog.transport
string
query
False
Filter by syslog.transport
syslog.port
integer
query
False
Filter by syslog.port
type
string
query
False
Filter by type
destination
string
query
False
Filter by destination
connectivity.state
string
query
False
Filter by connectivity.state
  • Introduced in: 9.11
connectivity.errors.node.uuid
string
query
False
Filter by connectivity.errors.node.uuid
connectivity.errors.node.name
string
query
False
Filter by connectivity.errors.node.name
connectivity.errors.message.message
string
query
False
Filter by connectivity.errors.message.message
connectivity.errors.message.arguments.code
string
query
False
Filter by connectivity.errors.message.arguments.code
connectivity.errors.message.arguments.message
string
query
False
Filter by connectivity.errors.message.arguments.message
connectivity.errors.message.code
string
query
False
Filter by connectivity.errors.message.code
access_control_role.name
string
query
False
Filter by access_control_role.name
  • Introduced in: 9.13
certificate.ca
string
query
False
Filter by certificate.ca
  • maxLength: 256
  • minLength: 1
certificate.name
string
query
False
Filter by certificate.name
certificate.serial_number
string
query
False
Filter by certificate.serial_number
  • maxLength: 40
  • minLength: 1
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "access_control_role": {
        "name": "admin"
      "certificate": {
        "ca": "VeriSign",
        "name": "string",
        "serial_number": 1234567890
      "connectivity": {
        "errors": [
            "message": {
              "arguments": [
                  "code": "string",
                  "message": "string"
              "code": "4",
              "message": "entry doesn't exist"
            "node": {
              "name": "node1",
        "state": "fail"
      "destination": "administrator@mycompany.com",
      "filters": [
          "name": "important-events"
      "name": "Admin_Email",
      "syslog": {
        "format": {
          "hostname_override": "string",
          "message": "string",
          "timestamp_override": "string"
        "port": 514,
        "transport": "string"
      "system_defined": 1,
      "type": "email"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
access_control_role
Indicates the access control role that created the event destination and is used to control access to the destination based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset.
_links
_links
name
string
Role name
certificate
Specifies the client-side certificate used by the ONTAP system when mutual authentication is required. This object is only applicable for rest_api type destinations. Both the ca and serial_number fields must be specified when configuring a certificate in a PATCH or POST request. The name field is read-only and cannot be used to configure a client-side certificate.
_links
_links
ca
string
Client certificate issuing CA
name
string
Certificate name
serial_number
string
Client certificate serial number
arguments
code
string
Argument code
message
string
Message argument
message
Information to be displayed to the user.
arguments
array[arguments]
Message arguments
code
string
Unique message code.
message
string
User message.
node
_links
_links
name
string
uuid
string
errors
Error object included in the event of connectivity failure.
message
message
node
node
connectivity
errors
array[errors]
A list of errors encountered during connectivity checks.
state
string
Current connectivity state.
filters
_links
_links
name
string
format
hostname_override
string
Syslog Hostname Format Override. The supported hostname formats are no_override (hostname format based on the syslog.format.message property i.e. fqdn if syslog.format.message is rfc_5424, hostname_only if syslog.format.message is legacy_netapp), fqdn (Fully Qualified Domain Name) and hostname_only.
message
string
Syslog Message Format. The supported message formats are legacy_netapp (format: <PRIVAL>TIMESTAMP [HOSTNAME:Event-name:Event-severity]: MSG) and rfc_5424 (format: <PRIVAL>VERSION TIMESTAMP HOSTNAME Event-source - Event-name - MSG).
timestamp_override
string
Syslog Timestamp Format Override. The supported timestamp formats are no_override (timestamp format based on the syslog.format.message property i.e. rfc_3164 if syslog.format.message is legacy_netapp, iso_8601_local_time if syslog.format.message is rfc_5424), rfc_3164 (format: Mmm dd hh:mm:ss), iso_8601_local_time (format: YYYY-MM-DDThh:mm:ss+/-hh:mm) and iso_8601_utc (format: YYYY-MM-DDThh:mm:ssZ).
syslog
format
format
port
integer
Syslog Port.
transport
string
Syslog Transport Protocol.
records
_links
_links
access_control_role
access_control_role
certificate
certificate
  • Introduced in: 9.6
connectivity
connectivity
destination
string
Event destination
filters
array[filters]
name
string
Destination name. Valid in POST.
syslog
syslog
system_defined
boolean
Flag indicating system-defined destinations.
type
string
Type of destination. Valid in POST.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
