Retrieve a collection of event destinations
Retrieves a list of event destinations, which helps you understand where event notifications are sent within your system. Use this information to manage and configure event notifications effectively.
HTTP method and endpoint
GET /support/ems/destinations
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of event destinations.
Related ONTAP commands
event notification destination show -
event notification show
destination |
string |
query |
False |
Filter by destination |
filters.name |
string |
query |
False |
Filter by filters.name |
certificate.ca |
string |
query |
False |
Filter by certificate.ca |
certificate.serial_number |
string |
query |
False |
Filter by certificate.serial_number |
name |
string |
query |
False |
Filter by name |
type |
string |
query |
False |
Filter by type |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": "3",
"records": [
"certificate": {
"ca": "VeriSign",
"serial_number": "1234567890"
"destination": "administrator@mycompany.com",
"filters": [
"name": "important-events"
"name": "Admin_Email",
"type": "email"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
certificate
Certificate information is valid for the "rest_api" type.
ca |
string |
Client certificate issuing CA |
serial_number |
string |
Client certificate serial number |
filters
_links |
name |
string |
records
_links |
certificate |
Certificate information is valid for the "rest_api" type. |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
Destination name. Valid in POST. |
type |
string |
Type of destination. Valid in POST. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
