Retrieve a collection of event destinations
Accesses a collection of event destinations to review and manage where notifications are sent in response to system events. This is useful for ensuring that critical alerts reach the appropriate monitoring systems or personnel.
HTTP method and endpoint
GET /support/ems/destinations
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of event destinations.
Related ONTAP commands
event notification destination show -
event notification show
type |
string |
query |
False |
Filter by type |
filters.name |
string |
query |
False |
Filter by filters.name |
syslog.format.message |
string |
query |
False |
Filter by syslog.format.message
syslog.format.timestamp_override |
string |
query |
False |
Filter by syslog.format.timestamp_override
syslog.format.hostname_override |
string |
query |
False |
Filter by syslog.format.hostname_override
syslog.transport |
string |
query |
False |
Filter by syslog.transport
syslog.port |
integer |
query |
False |
Filter by syslog.port
destination |
string |
query |
False |
Filter by destination |
system_defined |
boolean |
query |
False |
Filter by system_defined
access_control_role.name |
string |
query |
False |
Filter by access_control_role.name
connectivity.state |
string |
query |
False |
Filter by connectivity.state
connectivity.errors.node.name |
string |
query |
False |
Filter by connectivity.errors.node.name
connectivity.errors.node.uuid |
string |
query |
False |
Filter by connectivity.errors.node.uuid
connectivity.errors.message.code |
string |
query |
False |
Filter by connectivity.errors.message.code
connectivity.errors.message.arguments.code |
string |
query |
False |
Filter by connectivity.errors.message.arguments.code
connectivity.errors.message.arguments.message |
string |
query |
False |
Filter by connectivity.errors.message.arguments.message
connectivity.errors.message.message |
string |
query |
False |
Filter by connectivity.errors.message.message
certificate.name |
string |
query |
False |
Filter by certificate.name
certificate.ca |
string |
query |
False |
Filter by certificate.ca
certificate.serial_number |
string |
query |
False |
Filter by certificate.serial_number
name |
string |
query |
False |
Filter by name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"access_control_role": {
"name": "admin"
"certificate": {
"ca": "VeriSign",
"name": "string",
"serial_number": 1234567890
"connectivity": {
"errors": [
"message": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"node": {
"name": "node1",
"state": "fail"
"destination": "administrator@mycompany.com",
"filters": [
"name": "important-events"
"name": "Admin_Email",
"syslog": {
"format": {
"hostname_override": "string",
"message": "string",
"timestamp_override": "string"
"port": 514,
"transport": "string"
"system_defined": 1,
"type": "email"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
access_control_role
Indicates the access control role that created the event destination and is used to control access to the destination based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset.
_links |
name |
string |
Role name |
certificate
Specifies the client-side certificate used by the ONTAP system when mutual authentication is required. This object is only applicable for rest_api type destinations. Both the ca and serial_number fields must be specified when configuring a certificate in a PATCH or POST request. The name field is read-only and cannot be used to configure a client-side certificate.
_links |
ca |
string |
Client certificate issuing CA |
name |
string |
Certificate name |
serial_number |
string |
Client certificate serial number |
arguments
code |
string |
Argument code |
message |
string |
Message argument |
message
Information to be displayed to the user.
arguments |
array[arguments] |
Message arguments |
code |
string |
Unique message code. |
message |
string |
User message. |
node
_links |
name |
string |
uuid |
string |
errors
Error object included in the event of connectivity failure.
message |
Information to be displayed to the user. |
node |
connectivity
errors |
array[errors] |
A list of errors encountered during connectivity checks. |
state |
string |
Current connectivity state. |
filters
_links |
name |
string |
format
hostname_override |
string |
Syslog Hostname Format Override. The supported hostname formats are no_override (hostname format based on the syslog.format.message property i.e. fqdn if syslog.format.message is rfc_5424, hostname_only if syslog.format.message is legacy_netapp), fqdn (Fully Qualified Domain Name) and hostname_only. |
message |
string |
Syslog Message Format. The supported message formats are legacy_netapp (format: <PRIVAL>TIMESTAMP [HOSTNAME:Event-name:Event-severity]: MSG) and rfc_5424 (format: <PRIVAL>VERSION TIMESTAMP HOSTNAME Event-source - Event-name - MSG). |
string |
Syslog Timestamp Format Override. The supported timestamp formats are no_override (timestamp format based on the syslog.format.message property i.e. rfc_3164 if syslog.format.message is legacy_netapp, iso_8601_local_time if syslog.format.message is rfc_5424), rfc_3164 (format: Mmm dd hh:mm:ss), iso_8601_local_time (format: YYYY-MM-DDThh:mm:ss+/-hh:mm) and iso_8601_utc (format: YYYY-MM-DDThh:mm:ssZ). |
syslog
format |
port |
integer |
Syslog Port. |
transport |
string |
Syslog Transport Protocol. |
records
_links |
access_control_role |
Indicates the access control role that created the event destination and is used to control access to the destination based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset. |
certificate |
connectivity |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
Destination name. Valid in POST. |
syslog |
system_defined |
boolean |
Flag indicating system-defined destinations. |
type |
string |
Type of destination. Valid in POST. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
