Retrieve a collection of event destinations
Retrieves a list of event destinations to monitor and manage where system events are sent. This helps you configure notifications effectively based on your requirements.
HTTP method and endpoint
GET /support/ems/destinations
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of event destinations.
Related ONTAP commands
event notification destination show -
event notification show
destination |
string |
query |
False |
Filter by destination |
syslog.port |
integer |
query |
False |
Filter by syslog.port
syslog.format.message |
string |
query |
False |
Filter by syslog.format.message
syslog.format.hostname_override |
string |
query |
False |
Filter by syslog.format.hostname_override
syslog.format.timestamp_override |
string |
query |
False |
Filter by syslog.format.timestamp_override
syslog.transport |
string |
query |
False |
Filter by syslog.transport
certificate.name |
string |
query |
False |
Filter by certificate.name
certificate.ca |
string |
query |
False |
Filter by certificate.ca
certificate.serial_number |
string |
query |
False |
Filter by certificate.serial_number
system_defined |
boolean |
query |
False |
Filter by system_defined
access_control_role.name |
string |
query |
False |
Filter by access_control_role.name
connectivity.state |
string |
query |
False |
Filter by connectivity.state
connectivity.errors.message.arguments.message |
string |
query |
False |
Filter by connectivity.errors.message.arguments.message
connectivity.errors.message.arguments.code |
string |
query |
False |
Filter by connectivity.errors.message.arguments.code
connectivity.errors.message.code |
string |
query |
False |
Filter by connectivity.errors.message.code
connectivity.errors.message.message |
string |
query |
False |
Filter by connectivity.errors.message.message
connectivity.errors.node.name |
string |
query |
False |
Filter by connectivity.errors.node.name
connectivity.errors.node.uuid |
string |
query |
False |
Filter by connectivity.errors.node.uuid
name |
string |
query |
False |
Filter by name |
type |
string |
query |
False |
Filter by type |
filters.name |
string |
query |
False |
Filter by filters.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[records] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"access_control_role": {
"name": "admin"
"certificate": {
"ca": "VeriSign",
"name": "string",
"serial_number": 1234567890
"connectivity": {
"errors": [
"message": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"message": "entry doesn't exist"
"node": {
"name": "node1",
"state": "fail"
"destination": "administrator@mycompany.com",
"filters": [
"name": "important-events"
"name": "Admin_Email",
"syslog": {
"format": {
"hostname_override": "string",
"message": "string",
"timestamp_override": "string"
"port": 514,
"transport": "string"
"system_defined": 1,
"type": "email"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
access_control_role
Indicates the access control role that created the event destination and is used to control access to the destination based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset.
_links |
name |
string |
Role name |
certificate
Specifies the client-side certificate used by the ONTAP system when mutual authentication is required. This object is only applicable for rest_api type destinations. Both the ca and serial_number fields must be specified when configuring a certificate in a PATCH or POST request. The name field is read-only and cannot be used to configure a client-side certificate.
_links |
ca |
string |
Client certificate issuing CA |
name |
string |
Certificate name |
serial_number |
string |
Client certificate serial number |
arguments
code |
string |
Argument code |
message |
string |
Message argument |
message
Information to be displayed to the user.
arguments |
array[arguments] |
Message arguments |
code |
string |
Unique message code. |
message |
string |
User message. |
node
_links |
name |
string |
uuid |
string |
errors
Error object included in the event of connectivity failure.
message |
Information to be displayed to the user. |
node |
connectivity
errors |
array[errors] |
A list of errors encountered during connectivity checks. |
state |
string |
Current connectivity state. |
filters
_links |
name |
string |
format
hostname_override |
string |
Syslog Hostname Format Override. The supported hostname formats are no_override (hostname format based on the syslog.format.message property i.e. fqdn if syslog.format.message is rfc_5424, hostname_only if syslog.format.message is legacy_netapp), fqdn (Fully Qualified Domain Name) and hostname_only. |
message |
string |
Syslog Message Format. The supported message formats are legacy_netapp (format: <PRIVAL>TIMESTAMP [HOSTNAME:Event-name:Event-severity]: MSG) and rfc_5424 (format: <PRIVAL>VERSION TIMESTAMP HOSTNAME Event-source - Event-name - MSG). |
string |
Syslog Timestamp Format Override. The supported timestamp formats are no_override (timestamp format based on the syslog.format.message property i.e. rfc_3164 if syslog.format.message is legacy_netapp, iso_8601_local_time if syslog.format.message is rfc_5424), rfc_3164 (format: Mmm dd hh:mm:ss), iso_8601_local_time (format: YYYY-MM-DDThh:mm:ss+/-hh:mm) and iso_8601_utc (format: YYYY-MM-DDThh:mm:ssZ). |
syslog
format |
port |
integer |
Syslog Port. |
transport |
string |
Syslog Transport Protocol. |
records
_links |
access_control_role |
Indicates the access control role that created the event destination and is used to control access to the destination based on role-based access control (RBAC) rules. If created by the 'admin' user, the field is unset. |
certificate |
connectivity |
destination |
string |
Event destination |
filters |
array[filters] |
name |
string |
Destination name. Valid in POST. |
syslog |
system_defined |
boolean |
Flag indicating system-defined destinations. |
type |
string |
Type of destination. Valid in POST. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
