REST API reference
Retrieve a collection of event destinations
Retrieves a list of event destinations, which helps you manage where event notifications are sent.
HTTP method and endpoint
GET /support/ems/destinations
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of event destinations.
  • event notification destination show
  • event notification show
connectivity.errors.node.uuid
string
query
False
Filter by connectivity.errors.node.uuid
  • Introduced in: 9.11
connectivity.errors.node.name
string
query
False
Filter by connectivity.errors.node.name
connectivity.errors.message.arguments.message
string
query
False
Filter by connectivity.errors.message.arguments.message
connectivity.errors.message.arguments.code
string
query
False
Filter by connectivity.errors.message.arguments.code
connectivity.errors.message.code
string
query
False
Filter by connectivity.errors.message.code
connectivity.errors.message.message
string
query
False
Filter by connectivity.errors.message.message
connectivity.state
string
query
False
Filter by connectivity.state
system_defined
boolean
query
False
Filter by system_defined
  • Introduced in: 9.10
certificate.name
string
query
False
Filter by certificate.name
certificate.ca
string
query
False
Filter by certificate.ca
  • maxLength: 256
  • minLength: 1
certificate.serial_number
string
query
False
Filter by certificate.serial_number
  • maxLength: 40
  • minLength: 1
filters.name
string
query
False
Filter by filters.name
name
string
query
False
Filter by name
type
string
query
False
Filter by type
destination
string
query
False
Filter by destination
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 3,
  "records": [
      "certificate": {
        "ca": "VeriSign",
        "name": "cert1",
        "serial_number": "1234567890"
      "connectivity": {
        "errors": [
            "message": {
              "arguments": [
                  "code": "string",
                  "message": "string"
              "code": "4",
              "message": "entry doesn't exist"
            "node": {
              "name": "node1",
        "state": "fail"
      "destination": "administrator@mycompany.com",
      "filters": [
          "name": "important-events"
      "name": "Admin_Email",
      "system_defined": 1,
      "type": "email"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
certificate
Security certificate object reference
_links
_links
ca
string
Client certificate issuing CA
name
string
Certificate name
serial_number
string
Client certificate serial number
arguments
code
string
Argument code
message
string
Message argument
message
Information to be displayed to the user.
arguments
array[arguments]
Message arguments
code
string
Unique message code.
message
string
User message.
node
_links
_links
name
string
uuid
string
errors
Error object included in the event of connectivity failure.
message
message
node
node
connectivity
errors
array[errors]
A list of errors encountered during connectivity checks.
state
string
Current connectivity state.
filters
_links
_links
name
string
records
_links
_links
certificate
certificate
connectivity
connectivity
destination
string
Event destination
filters
array[filters]
name
string
Destination name. Valid in POST.
system_defined
boolean
Flag indicating system-defined destinations.
type
string
Type of destination. Valid in POST.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
