REST API reference
Retrieve a collection of event destinations
Accesses a collection of event destinations to examine the current event notification settings and configurations in your system.
HTTP method and endpoint
GET /support/ems/destinations
Introduced in
ONTAP 9.6
Usage notes
Retrieves a collection of event destinations.
  • event notification destination show
  • event notification show
connectivity.state
string
query
False
Filter by connectivity.state
  • Introduced in: 9.11
connectivity.errors.node.name
string
query
False
Filter by connectivity.errors.node.name
connectivity.errors.node.uuid
string
query
False
Filter by connectivity.errors.node.uuid
connectivity.errors.message.code
string
query
False
Filter by connectivity.errors.message.code
connectivity.errors.message.arguments.message
string
query
False
Filter by connectivity.errors.message.arguments.message
connectivity.errors.message.arguments.code
string
query
False
Filter by connectivity.errors.message.arguments.code
connectivity.errors.message.message
string
query
False
Filter by connectivity.errors.message.message
certificate.serial_number
string
query
False
Filter by certificate.serial_number
  • maxLength: 40
  • minLength: 1
certificate.ca
string
query
False
Filter by certificate.ca
  • maxLength: 256
  • minLength: 1
certificate.name
string
query
False
Filter by certificate.name
type
string
query
False
Filter by type
system_defined
boolean
query
False
Filter by system_defined
  • Introduced in: 9.10
destination
string
query
False
Filter by destination
filters.name
string
query
False
Filter by filters.name
name
string
query
False
Filter by name
syslog.port
integer
query
False
Filter by syslog.port
  • Introduced in: 9.12
syslog.format.message
string
query
False
Filter by syslog.format.message
syslog.format.hostname_override
string
query
False
Filter by syslog.format.hostname_override
syslog.format.timestamp_override
string
query
False
Filter by syslog.format.timestamp_override
syslog.transport
string
query
False
Filter by syslog.transport
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value: 1
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[records]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "certificate": {
        "ca": "VeriSign",
        "name": "cert1",
        "serial_number": "1234567890"
      "connectivity": {
        "errors": [
            "message": {
              "arguments": [
                  "code": "string",
                  "message": "string"
              "code": "4",
              "message": "entry doesn't exist"
            "node": {
              "name": "node1",
        "state": "fail"
      "destination": "administrator@mycompany.com",
      "filters": [
          "name": "important-events"
      "name": "Admin_Email",
      "syslog": {
        "format": {
          "hostname_override": "string",
          "message": "string",
          "timestamp_override": "string"
        "port": 514,
        "transport": "string"
      "system_defined": 1,
      "type": "email"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
certificate
Specifies the client-side certificate used by the ONTAP system when mutual authentication is required. This object is only applicable for rest_api type destinations. Both the ca and serial_number fields must be specified when configuring a certificate in a PATCH or POST request. The name field is read-only and cannot be used to configure a client-side certificate.
_links
_links
ca
string
Client certificate issuing CA
name
string
Certificate name
serial_number
string
Client certificate serial number
arguments
code
string
Argument code
message
string
Message argument
message
arguments
array[arguments]
Message arguments
code
string
Unique message code.
message
string
User message.
node
_links
_links
name
string
uuid
string
errors
Error object included in the event of connectivity failure.
message
message
node
node
connectivity
errors
array[errors]
A list of errors encountered during connectivity checks.
state
string
Current connectivity state.
filters
_links
_links
name
string
format
hostname_override
string
Syslog Hostname Format Override. The supported hostname formats are no_override (hostname format based on the syslog.format.message property i.e. fqdn if syslog.format.message is rfc_5424, hostname_only if syslog.format.message is legacy_netapp), fqdn (Fully Qualified Domain Name) and hostname_only.
message
string
Syslog Message Format. The supported message formats are legacy_netapp (format: <PRIVAL>TIMESTAMP [HOSTNAME:Event-name:Event-severity]: MSG) and rfc_5424 (format: <PRIVAL>VERSION TIMESTAMP HOSTNAME Event-source - Event-name - MSG).
timestamp_override
string
Syslog Timestamp Format Override. The supported timestamp formats are no_override (timestamp format based on the syslog.format.message property i.e. rfc_3164 if syslog.format.message is legacy_netapp, iso_8601_local_time if syslog.format.message is rfc_5424), rfc_3164 (format: Mmm dd hh:mm:ss), iso_8601_local_time (format: YYYY-MM-DDThh:mm:ss+/-hh:mm) and iso_8601_utc (format: YYYY-MM-DDThh:mm:ssZ).
syslog
format
format
port
integer
Syslog Port.
transport
string
Syslog Transport Protocol.
records
_links
_links
certificate
certificate
  • Introduced in: 9.6
connectivity
connectivity
destination
string
Event destination
filters
array[filters]
name
string
Destination name. Valid in POST.
syslog
syslog
system_defined
boolean
Flag indicating system-defined destinations.
type
string
Type of destination. Valid in POST.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
