REST API reference
Update an S3 user configuration
Updates the S3 user configuration of a storage virtual machine (SVM) to modify user settings or regenerate access credentials. Use this action to manage and adjust user access to S3-compatible services within your ONTAP environment.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/users/{name}
Introduced in
ONTAP 9.7
Usage notes
Updates the S3 user configuration of an SVM.
Important notes
  • User access_key and secret_key pair can be regenerated using the PATCH operation.
  • User access_key and secret_key is returned in a PATCH operation if the "regenerate_keys" field is specified as true.
  • regenerate_keys - Specifies if secret_key and access_key need to be regenerated.
  • comment - Any information related to the S3 user.
  • vserver object-store-server user show
  • vserver object-store-server user regenerate-keys
name
string
path
True
User name
regenerate_keys
boolean
query
False
Specifies whether or not to regenerate the user keys.
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
access_key
string
Specifies the access key for the user.
comment
string
Can contain any additional information about the user being created or modified.
svm
svm
Example request
  "access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
  "comment": "S3 user",
  "svm": {
    "name": "svm1",
Status: 200, Ok
num_records
integer
Number of records
records
array[s3_service_user_post_response]
  "records": [
      "name": "user-1",
      "secret_key": "A20_tDhC_cux2C2BmtL45bXB_a_Q65c_96FsAcOdo14Az8V31jBKDTc0uCL62Bh559gPB8s9rrn0868QrF38_1dsV2u1_9H2tSf3qQ5xp9NT259C6z_GiZQ883Qn63X1"
Status: Default
ONTAP Error Response Codes
Error Code Description
92405792
Failed to regenerate access-key and secret-key for user.
string
svm
name
string
The name of the SVM.
uuid
string
s3_user
This is a container of S3 users.
access_key
string
comment
string
svm
svm
access_key
string
name
string
The name of the user.
secret_key
string
Specifies the secret key for the user.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
