Update an S3 user configuration
Updates the S3 user configuration for a specific storage virtual machine (SVM). This endpoint is useful when you need to modify existing user settings or regenerate access keys as part of managing your object storage environment.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/users/{name}
Introduced in
ONTAP 9.7
Usage notes
Updates the S3 user configuration of an SVM.
Important notes
User access_key and secret_key pair can be regenerated using the PATCH operation.
User access_key and secret_key is returned in a PATCH operation if the "regenerate_keys" field is specified as true.
Recommended optional properties
regenerate_keys- Specifies if secret_key and access_key need to be regenerated. -
comment- Any information related to the S3 user.
Related ONTAP commands
vserver object-store-server user show -
vserver object-store-server user regenerate-keys
Learn more
name |
string |
path |
True |
User name |
regenerate_keys |
boolean |
query |
False |
Specifies whether or not to regenerate the user keys.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
svm |
Example request
"access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
"comment": "S3 user",
"svm": {
"name": "svm1",
Status: 200, Ok
num_records |
integer |
Number of records |
records |
"records": [
"name": "user-1",
"secret_key": "A20_tDhC_cux2C2BmtL45bXB_a_Q65c_96FsAcOdo14Az8V31jBKDTc0uCL62Bh559gPB8s9rrn0868QrF38_1dsV2u1_9H2tSf3qQ5xp9NT259C6z_GiZQ883Qn63X1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405792 |
Failed to regenerate access-key and secret-key for user. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
s3_user
This is a container of S3 users.
access_key |
string |
comment |
string |
svm |
collection_links
s3_service_user_post_response
access_key |
string |
name |
string |
The name of the user. |
secret_key |
string |
Specifies the secret key for the user. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
