Update an S3 user configuration
Updates the configuration for an S3 user associated with a Storage Virtual Machine (SVM). This operation is useful when you need to modify user settings or regenerate access credentials for enhanced security.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/users/{name}
Introduced in
ONTAP 9.7
Usage notes
Updates the S3 user configuration of an SVM.
Important notes
User access_key and secret_key pair can be regenerated using the PATCH operation.
User access_key and secret_key is returned in a PATCH operation if the "regenerate_keys" field is specified as true.
Recommended optional properties
regenerate_keys- Specifies if secret_key and access_key need to be regenerated. -
comment- Any information related to the S3 user.
Related ONTAP commands
vserver object-store-server user show -
vserver object-store-server user regenerate-keys
Learn more
name |
string |
path |
True |
User name |
regenerate_keys |
boolean |
query |
False |
Specifies whether or not to regenerate the user keys.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
svm |
Example request
"access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
"comment": "S3 user",
"svm": {
"name": "svm1",
Status: 200, Ok
num_records |
integer |
Number of records |
records |
"num_records": 1,
"records": [
"name": "user-1",
"secret_key": "A20_tDhC_cux2C2BmtL45bXB_a_Q65c_96FsAcOdo14Az8V31jBKDTc0uCL62Bh559gPB8s9rrn0868QrF38_1dsV2u1_9H2tSf3qQ5xp9NT259C6z_GiZQ883Qn63X1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405792 |
Failed to regenerate access-key and secret-key for user. |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
s3_user
This is a container of S3 users.
access_key |
string |
comment |
string |
svm |
collection_links
s3_service_user_post_response
access_key |
string |
name |
string |
The name of the user. |
secret_key |
string |
Specifies the secret key for the user. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
