Update an S3 user configuration
Updates the S3 user configuration for an SVM to modify user settings and manage access keys effectively. This is useful when you need to renew or delete access credentials for security or operational reasons.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/users/{name}
Introduced in
ONTAP 9.7
Usage notes
Updates the S3 user configuration of an SVM.
Important notes
User access_key and secret_key pair can be regenerated using the PATCH operation.
User access_key and secret_key is returned in a PATCH operation if the "regenerate_keys" field is specified as true.
If "regenerate_keys" is true and user keys have expiry configuration, then "key_expiry_time" is also returned as part of response.
User access_key and secret_key pair can be deleted using the PATCH operation.
Recommended optional properties
regenerate_keys- Specifies if secret_key and access_key need to be regenerated. -
delete_keys- Specifies if secret_key and access_key need to be deleted. -
comment- Any information related to the S3 user.
Related ONTAP commands
vserver object-store-server user show -
vserver object-store-server user regenerate-keys -
vserver object-store-server user delete-keys
Learn more
name |
string |
path |
True |
User name |
regenerate_keys |
boolean |
query |
False |
Specifies whether or not to regenerate the user keys.
delete_keys |
boolean |
query |
False |
Specifies whether or not to delete the user keys.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
key_expiry_time |
string |
Specifies the date and time after which keys expire and are no longer valid. |
key_id |
integer |
Specifies the identifier of an S3 user key that needs to be generated or deleted. The key_id can either be '1' or '2'. |
key_time_to_live |
string |
Indicates the time period from when this parameter is specified:
keys |
array[keys] |
Specifies the keys associated with an S3 User. |
secret_key |
string |
Specifies the secret key for the user. |
svm |
Example request
"access_key": "<AWS-ACCESS-KEY-ID>",
"comment": "S3 user",
"key_expiry_time": "2024-01-01 00:00:00 +0000",
"key_id": 1,
"key_time_to_live": "PT6H3M",
"keys": [
"expiry_time": "2024-01-01 00:00:00 +0000",
"id": 1,
"time_to_live": "PT6H3M"
"secret_key": "<AWS-SECRET-ACCESS-KEY>",
"svm": {
"name": "svm1",
Status: 200, Ok
num_records |
integer |
Number of records |
records |
"num_records": 1,
"records": [
"name": "user-1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405792 |
Failed to regenerate access-key and secret-key for user. |
92406082 |
Cannot perform "regenerate_keys" and "delete_keys" operations simultaneously on an S3 user. |
92406081 |
The "regenerate_keys" operation on S3 User "user-2" in SVM "vs1" succeeded. However, modifying all of the other S3 user properties failed. Reason: resource limit exceeded. Retry the operation again without specifying the "regenerate_keys" parameter. |
92406080 |
Cannot delete root user keys because there exists at least one S3 SnapMirror relationship that is using these keys. |
92406083 |
The maximum supported value for user key expiry configuration is "1095" days. |
92406088 |
The "key_time_to_live" parameter can only be used when the "regenerate_keys" operation is performed. |
92406096 |
The user does not have permission to access the requested resource \"{0}\". |
92406097 |
Internal error. The operation configuration is not correct. |
| 92406108 | The "key_id" field must be used with either the "regenerate_keys" or "delete_keys" operation. | 92406196 | The specified value for the "key_time_to_live" field cannot be greater than the maximum limit specified for the "max_key_time_to_live" field in the object store server. | | 92406197 | Object store user "user-2" must have a non-zero value for the "key_time_to_live" field because the maximum limit specified for the "max_key_time_to_live" field in the object store server is not zero. | 92406200 | An object store user with the same access-key already exists. | | 92406201 | Missing access-key or secret-key. Either provide both of the keys or none. If not provided, keys are generated automatically. | | 92406202 | The "delete_keys" operation must be performed without specifying the user keys. | | 92406205 | The object store user access key contains invalid characters. Valid characters are 0-9 and A-Z. | | 92406308 | Cannot disable user "user1" in SVM "vs1" because the user belongs to at least one object store group. Remove the user from all groups before disabling the user. |
keys
Specifies a key associated with an S3 user. At most only two keys can be associated with a user.
access_key |
string |
expiry_time |
string |
id |
integer |
Specifies an S3 user key identifier. Each user can only have a maximum of two keys. The key_id can either be '1' or '2'. |
time_to_live |
string |
href |
string |
_links
svm
name |
string |
uuid |
string |
s3_user
This is a container of S3 users.
access_key |
string |
comment |
string |
key_expiry_time |
string |
key_id |
integer |
key_time_to_live |
string |
keys |
array[keys] |
secret_key |
string |
svm |
collection_links
s3_service_user_post_response
access_key |
string |
key_expiry_time |
string |
Specifies the date and time after which the keys expire and are no longer valid. |
name |
string |
The name of the user. |
secret_key |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
