Update an S3 user configuration
Modifies the configuration of an S3 user for a storage virtual machine (SVM). This endpoint is useful when you need to update user credentials or settings in your storage environment.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/users/{name}
Introduced in
ONTAP 9.7
Usage notes
Updates the S3 user configuration of an SVM.
Important notes
User access_key and secret_key pair can be regenerated using the PATCH operation.
User access_key and secret_key is returned in a PATCH operation if the "regenerate_keys" field is specified as true.
If "regenerate_keys" is true and user keys have expiry configuration, then "key_expiry_time" is also returned as part of response.
User access_key and secret_key pair can be deleted using the PATCH operation.
Recommended optional properties
regenerate_keys- Specifies if secret_key and access_key need to be regenerated. -
delete_keys- Specifies if secret_key and access_key need to be deleted. -
comment- Any information related to the S3 user.
Related ONTAP commands
vserver object-store-server user show -
vserver object-store-server user regenerate-keys -
vserver object-store-server user delete-keys
Learn more
name |
string |
path |
True |
User name |
regenerate_keys |
boolean |
query |
False |
Specifies whether or not to regenerate the user keys.
delete_keys |
boolean |
query |
False |
Specifies whether or not to delete the user keys.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
key_expiry_time |
string |
Specifies the date and time after which keys expire and are no longer valid. |
key_time_to_live |
string |
Indicates the time period from when this parameter is specified:
svm |
Example request
"access_key": "<AWS-ACCESS-KEY-ID>",
"comment": "S3 user",
"key_expiry_time": "2023-12-31 19:00:00 -0500",
"key_time_to_live": "PT6H3M",
"svm": {
"name": "svm1",
Status: 200, Ok
num_records |
integer |
Number of records |
records |
"num_records": 1,
"records": [
"name": "user-1",
"secret_key": "<AWS-SECRET-ACCESS-KEY>"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405792 |
Failed to regenerate access-key and secret-key for user. |
92406082 |
Cannot perform "regenerate_keys" and "delete_keys" operations simultaneously on an S3 user. |
92406081 |
The "regenerate_keys" operation on S3 User "user-2" in SVM "vs1" succeeded. However, modifying all of the other S3 user properties failed. Reason: resource limit exceeded. Retry the operation again without specifying the "regenerate_keys" parameter. |
92406080 |
Cannot delete root user keys because there exists at least one S3 SnapMirror relationship that is using these keys. |
92406083 |
The maximum supported value for user key expiry configuration is "1095" days. |
92406088 |
The "key_time_to_live" parameter can only be used when the "regenerate_keys" operation is performed. |
92406096 |
The user does not have permission to access the requested resource "{0}". |
92406097 |
Internal error. The operation configuration is not correct. |
92406196 |
The specified value for the "key_time_to_live" field cannot be greater than the maximum limit specified for the "max_key_time_to_live" field in the object store server. |
92406197 |
href |
string |
_links
svm
name |
string |
uuid |
string |
s3_user
This is a container of S3 users.
access_key |
string |
comment |
string |
key_expiry_time |
string |
key_time_to_live |
string |
svm |
collection_links
s3_service_user_post_response
access_key |
string |
key_expiry_time |
string |
Specifies the date and time after which the keys expire and are no longer valid. |
name |
string |
The name of the user. |
secret_key |
string |
Specifies the secret key for the user. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
