Update an S3 user configuration
PATCH /protocols/s3/services/{svm.uuid}/users/{name}
Updates the S3 user configuration of an SVM.
Important notes
User access_key and secret_key pair can be regenerated using the PATCH operation.
User access_key and secret_key is returned in a PATCH operation if the "regenerate_keys" field is specified as true.
Recommended optional properties
regenerate_keys- Specifies if secret_key and access_key need to be regenerated. -
comment- Any information related to the S3 user.
Related ONTAP commands
vserver object-store-server user show -
vserver object-store-server user regenerate-keys
Learn more
svm.uuid  |
string  |
path  |
True  |
UUID of the SVM to which this object belongs.  |
name  |
string  |
path  |
True  |
User name  |
regenerate_keys  |
boolean  |
query  |
False  |
Specifies whether or not to regenerate the user keys.
Request Body
| Name | Type | Description |
access_key  |
string  |
Specifies the access key for the user.  |
comment  |
string  |
Can contain any additional information about the user being created or modified.  |
svm  |
Example request
  "access_key": "Pz3SB54G2B_6dsXQPrA5HrTPcf478qoAW6_Xx6qyqZ948AgZ_7YfCf_9nO87YoZmskxx3cq41U2JAH2M3_fs321B4rkzS3a_oC5_8u7D8j_45N8OsBCBPWGD_1d_ccfq",
  "comment": "S3 user",
  "svm": {
        "href": "/api/resourcelink"
    "name": "svm1",
Status: 200, Ok
num_records  |
integer  |
Number of records  |
records  |
  "records": [
        "next": {
      "name": "user-1",
      "secret_key": "A20_tDhC_cux2C2BmtL45bXB_a_Q65c_96FsAcOdo14Az8V31jBKDTc0uCL62Bh559gPB8s9rrn0868QrF38_1dsV2u1_9H2tSf3qQ5xp9NT259C6z_GiZQ883Qn63X1"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405792  |
Failed to regenerate access-key and secret-key for user.  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
svm
_links  |
name  |
string  |
The name of the SVM.  |
uuid  |
string  |
The unique identifier of the SVM.  |
s3_user
This is a container of S3 users.
access_key  |
string  |
comment  |
string  |
svm  |
collection_links
next  |
self  |
s3_service_user_post_response
_links  |
access_key  |
string  |
name  |
string  |
The name of the user.  |
secret_key  |
string  |
Specifies the secret key for the user.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
