Update an S3 user configuration
Updates the configuration for an S3 user within an SVM to manage access credentials and settings. Use this endpoint when you need to modify existing user configurations or regenerate access keys.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/users/{name}
Introduced in
ONTAP 9.7
Usage notes
Updates the S3 user configuration of an SVM.
Important notes
User access_key and secret_key pair can be regenerated using the PATCH operation.
User access_key and secret_key is returned in a PATCH operation if the "regenerate_keys" field is specified as true.
If "regenerate_keys" is true and user keys have expiry configuration, then "key_expiry_time" is also returned as part of response.
User access_key and secret_key pair can be deleted using the PATCH operation.
Recommended optional properties
regenerate_keys- Specifies if secret_key and access_key need to be regenerated. -
delete_keys- Specifies if secret_key and access_key need to be deleted. -
comment- Any information related to the S3 user.
Related ONTAP commands
vserver object-store-server user show -
vserver object-store-server user regenerate-keys -
vserver object-store-server user delete-keys
Learn more
name |
string |
path |
True |
User name |
regenerate_keys |
boolean |
query |
False |
Specifies whether or not to regenerate the user keys.
delete_keys |
boolean |
query |
False |
Specifies whether or not to delete the user keys.
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
Request Body
| Name | Type | Description |
access_key |
string |
Specifies the access key for the user. |
comment |
string |
Can contain any additional information about the user being created or modified. |
key_expiry_time |
string |
Specifies the date and time after which keys expire and are no longer valid. |
key_time_to_live |
string |
Indicates the time period from when this parameter is specified:
svm |
Example request
"access_key": "HJAKU28M3SXTE2UXUACV",
"comment": "S3 user",
"key_expiry_time": "2023-12-31 19:00:00 -0500",
"key_time_to_live": "PT6H3M",
"svm": {
"name": "svm1",
Status: 200, Ok
num_records |
integer |
Number of records |
records |
"num_records": 1,
"records": [
"name": "user-1",
"secret_key": "BcA_HX6If458llhnx3n1TCO3mg4roCXG0ddYf_cJ"
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
92405792 |
Failed to regenerate access-key and secret-key for user. |
92406082 |
Cannot perform "regenerate_keys" and "delete_keys" operations simultaneously on an S3 user. |
92406081 |
The "regenerate_keys" operation on S3 User "user-2" in SVM "vs1" succeeded. However, modifying all of the other S3 user properties failed. Reason: resource limit exceeded. Retry the operation again without specifying the "regenerate_keys" parameter. |
92406080 |
Cannot delete root user keys because there exists at least one S3 SnapMirror relationship that is using these keys. |
92406083 |
The maximum supported value for user key expiry configuration is "1095" days. |
92406088 |
The "key_time_to_live" parameter can only be used when the "regenerate_keys" operation is performed. |
92406096 |
The user does not have permission to access the requested resource \"{0}\". |
92406097 |
Internal error. The operation configuration is not correct. |
href |
string |
_links
svm
name |
string |
uuid |
string |
s3_user
This is a container of S3 users.
access_key |
string |
comment |
string |
key_expiry_time |
string |
key_time_to_live |
string |
svm |
collection_links
s3_service_user_post_response
access_key |
string |
name |
string |
The name of the user. |
secret_key |
string |
Specifies the secret key for the user. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
