REST API reference
Update an S3 user configuration
PATCH /protocols/s3/services/{svm.uuid}/users/{name}
Introduced In: 9.7
Updates the S3 user configuration of an SVM.
Important notes
  • User access_key and secret_key pair can be regenerated using the PATCH operation.
  • User access_key and secret_key is returned in a PATCH operation if the "regenerate_keys" field is specified as true.
  • If "regenerate_keys" is true and user keys have expiry configuration, then "key_expiry_time" is also returned as part of response.
  • User access_key and secret_key pair can be deleted using the PATCH operation.
  • regenerate_keys - Specifies if secret_key and access_key need to be regenerated.
  • delete_keys - Specifies if secret_key and access_key need to be deleted.
  • comment - Any information related to the S3 user.
  • vserver object-store-server user show
  • vserver object-store-server user regenerate-keys
  • vserver object-store-server user delete-keys
name
string
path
True
User name
regenerate_keys
boolean
query
False
Specifies whether or not to regenerate the user keys.
  • Default value:
delete_keys
boolean
query
False
Specifies whether or not to delete the user keys.
  • Introduced in: 9.14
  • Default value:
svm.uuid
string
path
True
Request Body
Name Type Description
access_key
string
Specifies the access key for the user.
comment
string
Can contain any additional information about the user being created or modified.
key_expiry_time
string
Specifies the date and time after which keys expire and are no longer valid.
key_time_to_live
string
Indicates the time period from when this parameter is specified:
  • when creating or modifying a user or
  • when the user keys were last regenerated, after which the user keys expire and are no longer valid.
  • Valid format is: 'PnDTnHnMnS|PnW'. For example, P2DT6H3M10S specifies a time period of 2 days, 6 hours, 3 minutes, and 10 seconds.
  • If the value specified is '0' seconds, then the keys won't expire.
secret_key
string
Specifies the secret key for the user.
svm
svm
Example request
  "access_key": "<AWS-ACCESS-KEY-ID>",
  "comment": "S3 user",
  "key_expiry_time": "2024-01-01 00:00:00 +0000",
  "key_time_to_live": "PT6H3M",
  "secret_key": "<AWS-SECRET-ACCESS-KEY>",
  "svm": {
    "name": "svm1",
Status: 200, Ok
num_records
integer
Number of records
records
array[s3_service_user_post_response]
  "num_records": 1,
  "records": [
      "name": "user-1",
Status: Default
ONTAP Error Response Codes
Error Code Description
92405792
Failed to regenerate access-key and secret-key for user.
92406082
Cannot perform "regenerate_keys" and "delete_keys" operations simultaneously on an S3 user.
92406081
The "regenerate_keys" operation on S3 User "user-2" in SVM "vs1" succeeded. However, modifying all of the other S3 user properties failed. Reason: resource limit exceeded. Retry the operation again without specifying the "regenerate_keys" parameter.
92406080
Cannot delete root user keys because there exists at least one S3 SnapMirror relationship that is using these keys.
92406083
The maximum supported value for user key expiry configuration is "1095" days.
92406088
The "key_time_to_live" parameter can only be used when the "regenerate_keys" operation is performed.
92406096
The user does not have permission to access the requested resource \"{0}\".
92406097
Internal error. The operation configuration is not correct.
92406196
The specified value for the "key_time_to_live" field cannot be greater than the maximum limit specified for the "max_key_time_to_live" field in the object store server.
| 92406197 | Object store user "user-2" must have a non-zero value for the "key_time_to_live" field because the maximum limit specified for the "max_key_time_to_live" field in the object store server is not zero. | 92406200 | An object store user with the same access-key already exists. | | 92406201 | Missing access-key or secret-key. Either provide both of the keys or none. If not provided, keys are generated automatically. | | 92406202 | The "delete_keys" operation must be performed without specifying the user keys. | | 92406205 | The object store user access key contains invalid characters. Valid characters are 0-9 and A-Z. | | 92406308 | Cannot disable user "user1" in SVM "vs1" because the user belongs to at least one object store group. Remove the user from all groups before disabling the user. |
string
svm
name
string
uuid
string
s3_user
This is a container of S3 users.
access_key
string
comment
string
key_expiry_time
string
key_time_to_live
string
secret_key
string
svm
svm
access_key
string
key_expiry_time
string
Specifies the date and time after which the keys expire and are no longer valid.
name
string
The name of the user.
secret_key
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
