REST API reference
Create a consistency group Snapshot copy
Creates a Snapshot copy of an existing consistency group. Use this operation to capture the state of the group for data protection and recovery purposes.
HTTP method and endpoint
POST /application/consistency-groups/{consistency_group.uuid}/snapshots
Introduced in
ONTAP 9.10
Required properties
  • consistency_group.uuid - Existing consistency group UUID in which to create the Snapshot copy.
string
path
True
The unique identifier of the consistency group to retrieve.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
Comment for the Snapshot copy.
consistency_group
consistency_group
The consistency group of the Snapshot copy.
consistency_type
string
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST.
create_time
string
Time the snapshot copy was created
is_partial
boolean
Indicates whether the Snapshot copy taken is partial or not.
missing_volumes
array[volume_reference]
List of volumes which are not in the Snapshot copy.
name
string
Name of the Snapshot copy.
snapmirror_label
string
Snapmirror Label for the Snapshot copy.
svm
svm_reference
uuid
string
The unique identifier of the Snapshot copy. The UUID is generated by ONTAP when the Snapshot copy is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
  • Introduced in: 9.10
Example request
  "comment": "My Snapshot copy comment",
  "consistency_group": {
    "name": "my_consistency_group",
  "consistency_type": "crash",
  "create_time": "2020-10-25T11:20:00Z",
  "is_partial": "",
  "missing_volumes": [
      "name": "volume1",
  "name": "string",
  "snapmirror_label": "sm_label",
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Status: 201, Created
Status: Default, Error
string
consistency_group
name
string
The name of the consistency group.
uuid
string
The unique identifier of the consistency group.
volume_reference
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
svm_reference
name
string
The name of the SVM.
uuid
string
consistency_group_snapshot
comment
string
consistency_group
consistency_group
consistency_type
string
create_time
string
is_partial
boolean
missing_volumes
name
string
snapmirror_label
string
svm
svm_reference
uuid
string
  • readOnly: 1
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
