REST API reference
Create a consistency group Snapshot copy
Creates a Snapshot copy for a consistency group, capturing its state at a specific point in time. This is useful for data protection and recovery scenarios.
HTTP method and endpoint
POST /application/consistency-groups/{consistency_group.uuid}/snapshots
Introduced in
ONTAP 9.10
Usage notes
Creates a Snapshot copy of an existing consistency group.
Required properties
  • consistency_group.uuid - Existing consistency group UUID in which to create the Snapshot copy.
string
path
True
The unique identifier of the consistency group to retrieve.
action
string
query
False
Initiates the Snapshot copy create operation. The start of the Snapshot copy operation can optionally use a timeout value specified by "action_timeout". The Snapshot copy is committed by calling PATCH on the Snapshot copy href link with action specified as "commit".
  • Introduced in: 9.11
  • enum: ["start"]
action_timeout
integer
query
False
Duration to complete the 2-phase Snapshot copy operation. This also specifies the maximum duration that the write-fence remains in effect on the volumes associated with this consistency group. Default is 7 seconds with a valid range of 5 to 120 seconds.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
Comment for the Snapshot copy.
consistency_group
consistency_group
The consistency group of the Snapshot copy.
consistency_type
string
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST.
create_time
string
Time the snapshot copy was created
is_partial
boolean
Indicates whether the Snapshot copy taken is partial or not.
missing_volumes
array[volume_reference]
List of volumes which are not in the Snapshot copy.
name
string
Name of the Snapshot copy.
snapmirror_label
string
Snapmirror Label for the Snapshot copy.
snapshot_volumes
array[consistency_group_volume_snapshot]
List of volume and snapshot identifiers for each volume in the Snapshot copy.
svm
svm_reference
uuid
string
The unique identifier of the Snapshot copy. The UUID is generated by ONTAP when the Snapshot copy is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
  • Introduced in: 9.10
  • x-nullable: true
write_fence
boolean
Specifies whether a write fence will be taken when creating the Snapshot copy. The default is false if there is only one volume in the consistency group, otherwise the default is true.
Example request
  "comment": "My Snapshot copy comment",
  "consistency_group": {
    "name": "my_consistency_group",
  "consistency_type": "crash",
  "create_time": "2020-10-25 07:20:00 -0400",
  "is_partial": "",
  "missing_volumes": [
      "name": "volume1",
  "name": "string",
  "snapmirror_label": "sm_label",
  "snapshot_volumes": [
      "snapshot": {
        "name": "this_snapshot",
      "volume": {
        "name": "volume1",
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default, Error
string
consistency_group
name
string
The name of the consistency group.
uuid
string
The unique identifier of the consistency group.
volume_reference
name
string
The name of the volume. This field cannot be specified in a POST or PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
snapshot_reference
name
string
uuid
string
snapshot
snapshot_reference
volume
volume_reference
svm_reference
name
string
uuid
string
consistency_group_snapshot
comment
string
consistency_group
consistency_group
consistency_type
string
create_time
string
is_partial
boolean
missing_volumes
name
string
snapmirror_label
string
snapshot_volumes
svm
svm_reference
uuid
string
  • readOnly: 1
  • x-nullable: true
write_fence
boolean
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
