Create a consistency group snapshot
Creates a snapshot of an existing consistency group. Use this to preserve the state of the group at a particular point in time.
HTTP method and endpoint
POST /application/consistency-groups/{consistency_group.uuid}/snapshots
Introduced in
ONTAP 9.10
Required properties
consistency_group.uuid- Existing consistency group UUID in which to create the snapshot.
consistency_group.uuid |
string |
path |
True |
The unique identifier of the consistency group to retrieve. |
action |
string |
query |
False |
Initiates the snapshot create operation. The start of the snapshot operation can optionally use a timeout value specified by "action_timeout". The snapshot is committed by calling PATCH on the snapshot href link with action specified as "commit".
action_timeout |
integer |
query |
False |
Duration to complete the 2-phase snapshot operation. This also specifies the maximum duration that the write-fence remains in effect on the volumes associated with this consistency group. Default is 7 seconds with a valid range of 5 to 120 seconds.
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
Comment for the snapshot. |
consistency_group |
The consistency group of the snapshot. |
consistency_type |
string |
Consistency type. This is for categorization purposes only. A snapshot should not be set to 'application consistent' unless the host application is quiesced for the snapshot. Valid in POST. |
create_time |
string |
Time the snapshot copy was created |
is_partial |
boolean |
Indicates whether the snapshot taken is partial or not. |
luns |
array[luns] |
The list of LUNs in this snapshot. |
missing_luns |
array[lun_reference] |
List of LUNs that are not in the snapshot. |
missing_namespaces |
array[missing_namespaces] |
List of NVMe namespaces that are not in the snapshot. |
missing_volumes |
array[volume_reference] |
List of volumes which are not in the snapshot. |
name |
string |
Name of the snapshot. |
namespaces |
array[namespaces] |
The list of NVMe namespaces in this snapshot. |
reclaimable_space |
integer |
Space reclaimed when the snapshot is deleted, in bytes. |
restore_size |
integer |
Size of the consistency group if this snapshot is restored. |
snapmirror_label |
string |
Snapmirror Label for the snapshot. |
snapshot_volumes |
List of volume and snapshot identifiers for each volume in the snapshot. |
svm |
uuid |
string |
The unique identifier of the snapshot. The UUID is generated by ONTAP when the snapshot is created.
write_fence |
boolean |
Specifies whether a write fence will be taken when creating the snapshot. The default is false if there is only one volume in the consistency group, otherwise the default is true. |
Example request
"comment": "My snapshot comment",
"consistency_group": {
"name": "my_consistency_group",
"consistency_type": "crash",
"create_time": "2020-10-25 11:20:00 +0000",
"is_partial": "",
"luns": [
"name": "/vol/volume1/lun1",
"missing_luns": [
"missing_namespaces": [
"name": "/vol/volume1/namespace1",
"missing_volumes": [
"name": "volume1",
"name": "string",
"namespaces": [
"reclaimable_space": 0,
"restore_size": 4096,
"snapmirror_label": "sm_label",
"snapshot_volumes": [
"snapshot": {
"name": "this_snapshot",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53411918 |
Snapshot operation not permitted. |
53411921 |
Failed to create snapshot for consistency group. |
href |
string |
self_link
consistency_group
name |
string |
The name of the consistency group. |
uuid |
string |
The unique identifier of the consistency group. |
_links
luns
A reference to a LUN.
name |
string |
The name of a LUN. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume. LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional. |
uuid |
string |
The unique identifier of the LUN. |
lun_reference
name |
string |
uuid |
string |
missing_namespaces
A reference to a namespace.
name |
string |
The name of an NVMe namespace. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume. NVMe namespace names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional. |
uuid |
string |
The unique identifier of the NVMe namespace. |
volume_reference
name |
string |
The name of the volume. This field cannot be specified in a PATCH method. |
uuid |
string |
namespaces
name |
string |
uuid |
string |
snapshot_reference
name |
string |
uuid |
string |
consistency_group_volume_snapshot
snapshot |
volume |
svm_reference
name |
string |
uuid |
string |
consistency_group_snapshot
comment |
string |
consistency_group |
consistency_type |
string |
create_time |
string |
is_partial |
boolean |
luns |
array[luns] |
missing_luns |
missing_volumes |
name |
string |
namespaces |
array[namespaces] |
reclaimable_space |
integer |
restore_size |
integer |
snapmirror_label |
string |
snapshot_volumes |
svm |
uuid |
string |
write_fence |
boolean |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
