Create a consistency group Snapshot copy
Creates a Snapshot copy of a consistency group to capture its current state for data protection or recovery purposes.
HTTP method and endpoint
POST /application/consistency-groups/{consistency_group.uuid}/snapshots
Introduced in
ONTAP 9.10
Usage notes
Creates a Snapshot copy of an existing consistency group.
Required properties
consistency_group.uuid- Existing consistency group UUID in which to create the Snapshot copy.
consistency_group.uuid |
string |
path |
True |
The unique identifier of the consistency group to retrieve. |
action |
string |
query |
False |
Initiates the Snapshot copy create operation. The start of the Snapshot copy operation can optionally use a timeout value specified by "action_timeout". The Snapshot copy is commited by calling PATCH on the Snapshot copy href link with action specified as "commit".
action_timeout |
integer |
query |
False |
Duration to complete the 2-phase Snapshot copy operation. This also specifies the maximum duration that the write-fence remains in effect on the volumes associated with this consistency group. Default is 7 seconds with a valid range of 1 to 90 seconds.
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
Comment for the Snapshot copy. |
consistency_type |
string |
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST. |
name |
string |
Name of the Snapshot copy. |
snapmirror_label |
string |
Snapmirror Label for the Snapshot copy. |
svm |
Example request
"comment": "My Snapshot copy comment",
"consistency_type": "crash",
"is_partial": "",
"name": "string",
"snapmirror_label": "sm_label",
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Status: 201, Created
Status: Default, Error
href |
string |
self_link
consistency_group
The consistency group of the Snapshot copy.
name |
string |
The name of the consistency group. |
uuid |
string |
The unique identifier of the consistency group. |
_links
volume_reference
name |
string |
The name of the volume. |
uuid |
string |
svm_reference
name |
string |
The name of the SVM. |
uuid |
string |
consistency_group_snapshot
comment |
string |
consistency_type |
string |
name |
string |
snapmirror_label |
string |
svm |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
