REST API reference
Create a consistency group Snapshot copy
Creates a Snapshot copy of an existing consistency group. Use this to capture the state of the group at a specific point in time for data protection or recovery purposes.
HTTP method and endpoint
POST /application/consistency-groups/{consistency_group.uuid}/snapshots
Introduced in
ONTAP 9.10
Required properties
  • consistency_group.uuid - Existing consistency group UUID in which to create the Snapshot copy.
string
path
True
The unique identifier of the consistency group to retrieve.
action
string
query
False
Initiates the Snapshot copy create operation. The start of the Snapshot copy operation can optionally use a timeout value specified by "action_timeout". The Snapshot copy is commited by calling PATCH on the Snapshot copy href link with action specified as "commit".
  • Introduced in: 9.11
  • enum: ["start"]
action_timeout
integer
query
False
Duration to complete the 2-phase Snapshot copy operation. This also specifies the maximum duration that the write-fence remains in effect on the volumes associated with this consistency group. Default is 7 seconds with a valid range of 1 to 90 seconds.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
Comment for the Snapshot copy.
consistency_type
string
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST.
name
string
Name of the Snapshot copy.
snapmirror_label
string
Snapmirror Label for the Snapshot copy.
snapshot_volumes
array[consistency_group_volume_snapshot]
List of volume and snapshot identifiers for each volume in the Snapshot copy.
svm
svm_reference
Example request
  "comment": "My Snapshot copy comment",
  "consistency_type": "crash",
  "is_partial": "",
  "name": "string",
  "snapmirror_label": "sm_label",
  "snapshot_volumes": [
      "snapshot": {
        "name": "this_snapshot",
      "volume": {
        "name": "volume1",
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default, Error
string
consistency_group
The consistency group of the Snapshot copy.
name
string
The name of the consistency group.
uuid
string
The unique identifier of the consistency group.
volume_reference
name
string
The name of the volume.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
snapshot_reference
name
string
uuid
string
snapshot
snapshot_reference
volume
volume_reference
svm_reference
name
string
The name of the SVM.
uuid
string
consistency_group_snapshot
comment
string
consistency_type
string
name
string
snapmirror_label
string
snapshot_volumes
svm
svm_reference
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
