REST API reference
Create a consistency group snapshot
POST /application/consistency-groups/{consistency_group.uuid}/snapshots
Introduced In: 9.10
Creates a snapshot of an existing consistency group.
Required properties
  • consistency_group.uuid - Existing consistency group UUID in which to create the snapshot.
string
path
True
The unique identifier of the consistency group to retrieve.
action
string
query
False
Initiates the snapshot create operation. The start of the snapshot operation can optionally use a timeout value specified by "action_timeout". The snapshot is committed by calling PATCH on the snapshot href link with action specified as "commit".
  • Introduced in: 9.11
  • enum: ["start"]
action_timeout
integer
query
False
Duration to complete the 2-phase snapshot operation. This also specifies the maximum duration that the write-fence remains in effect on the volumes associated with this consistency group. Default is 7 seconds with a valid range of 5 to 120 seconds.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
comment
string
Comment for the snapshot.
consistency_group
consistency_group
The consistency group of the snapshot.
consistency_type
string
Consistency type. This is for categorization purposes only. A snapshot should not be set to 'application consistent' unless the host application is quiesced for the snapshot. Valid in POST.
create_time
string
Time the snapshot copy was created
is_partial
boolean
Indicates whether the snapshot taken is partial or not.
luns
array[luns]
The list of LUNs in this snapshot.
missing_luns
array[lun_reference]
List of LUNs that are not in the snapshot.
missing_namespaces
array[missing_namespaces]
List of NVMe namespaces that are not in the snapshot.
missing_volumes
array[volume_reference]
List of volumes which are not in the snapshot.
name
string
Name of the snapshot.
namespaces
array[namespaces]
The list of NVMe namespaces in this snapshot.
reclaimable_space
integer
Space reclaimed when the snapshot is deleted, in bytes.
restore_size
integer
Size of the consistency group if this snapshot is restored.
snapmirror_label
string
Snapmirror Label for the snapshot.
snapshot_volumes
array[consistency_group_volume_snapshot]
List of volume and snapshot identifiers for each volume in the snapshot.
svm
svm_reference
uuid
string
The unique identifier of the snapshot. The UUID is generated by ONTAP when the snapshot is created.
  • example: 1cd8a442-86d1-11e0-ae1c-123478563412
  • readOnly: 1
  • Introduced in: 9.10
  • x-nullable: true
write_fence
boolean
Specifies whether a write fence will be taken when creating the snapshot. The default is false if there is only one volume in the consistency group, otherwise the default is true.
Example request
  "comment": "My snapshot comment",
  "consistency_group": {
    "name": "my_consistency_group",
  "consistency_type": "crash",
  "create_time": "2020-10-25 11:20:00 +0000",
  "is_partial": "",
  "luns": [
      "name": "/vol/volume1/lun1",
  "missing_luns": [
  "missing_namespaces": [
      "name": "/vol/volume1/namespace1",
  "missing_volumes": [
      "name": "volume1",
  "name": "string",
  "namespaces": [
  "reclaimable_space": 0,
  "restore_size": 4096,
  "snapmirror_label": "sm_label",
  "snapshot_volumes": [
      "snapshot": {
        "name": "this_snapshot",
      "volume": {
        "name": "volume1",
  "svm": {
    "name": "svm1",
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
53411918
Snapshot operation not permitted.
53411921
Failed to create snapshot for consistency group.
string
consistency_group
name
string
The name of the consistency group.
uuid
string
The unique identifier of the consistency group.
luns
A reference to a LUN.
name
string
The name of a LUN. A LUN is located within a volume. Optionally, it can be located within a qtree in a volume.
LUN names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
uuid
string
The unique identifier of the LUN.
lun_reference
name
string
uuid
string
missing_namespaces
A reference to a namespace.
name
string
The name of an NVMe namespace. An NVMe namespace is located within a volume. Optionally, it can be located within a qtree in a volume.
NVMe namespace names are paths of the form "/vol/<volume>[/<qtree>]/<namespace>" where the qtree name is optional.
uuid
string
The unique identifier of the NVMe namespace.
volume_reference
name
string
The name of the volume. This field cannot be specified in a PATCH method.
uuid
string
  • example: 028baa66-41bd-11e9-81d5-00a0986138f7
  • Introduced in: 9.6
  • x-nullable: true
namespaces
name
string
uuid
string
snapshot_reference
name
string
uuid
string
snapshot
snapshot_reference
volume
volume_reference
svm_reference
name
string
uuid
string
consistency_group_snapshot
comment
string
consistency_group
consistency_group
consistency_type
string
create_time
string
is_partial
boolean
luns
array[luns]
missing_luns
missing_namespaces
missing_volumes
name
string
namespaces
array[namespaces]
reclaimable_space
integer
restore_size
integer
snapmirror_label
string
snapshot_volumes
svm
svm_reference
uuid
string
  • readOnly: 1
  • x-nullable: true
write_fence
boolean
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
