Create a consistency group Snapshot copy
Creates a Snapshot copy of a consistency group to preserve its current state. This is useful for backing up data or preparing for data recovery operations.
HTTP method and endpoint
POST /application/consistency-groups/{consistency_group.uuid}/snapshots
Introduced in
ONTAP 9.10
Usage notes
Creates a Snapshot copy of an existing consistency group.
Required properties
consistency_group.uuid- Existing consistency group UUID in which to create the Snapshot copy.
consistency_group.uuid |
string |
path |
True |
The unique identifier of the consistency group to retrieve. |
action |
string |
query |
False |
Initiates the Snapshot copy create operation. The start of the Snapshot copy operation can optionally use a timeout value specified by "action_timeout". The Snapshot copy is committed by calling PATCH on the Snapshot copy href link with action specified as "commit".
action_timeout |
integer |
query |
False |
Duration to complete the 2-phase Snapshot copy operation. This also specifies the maximum duration that the write-fence remains in effect on the volumes associated with this consistency group. Default is 7 seconds with a valid range of 5 to 120 seconds.
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
comment |
string |
Comment for the Snapshot copy. |
consistency_group |
The consistency group of the Snapshot copy. |
consistency_type |
string |
Consistency type. This is for categorization purposes only. A Snapshot copy should not be set to 'application consistent' unless the host application is quiesced for the Snapshot copy. Valid in POST. |
create_time |
string |
Time the snapshot copy was created |
is_partial |
boolean |
Indicates whether the Snapshot copy taken is partial or not. |
missing_volumes |
array[volume_reference] |
List of volumes which are not in the Snapshot copy. |
name |
string |
Name of the Snapshot copy. |
snapmirror_label |
string |
Snapmirror Label for the Snapshot copy. |
snapshot_volumes |
List of volume and snapshot identifiers for each volume in the Snapshot copy. |
svm |
uuid |
string |
The unique identifier of the Snapshot copy. The UUID is generated by ONTAP when the Snapshot copy is created.
write_fence |
boolean |
Specifies whether a write fence will be taken when creating the Snapshot copy. The default is false if there is only one volume in the consistency group, otherwise the default is true. |
Example request
"comment": "My Snapshot copy comment",
"consistency_group": {
"name": "my_consistency_group",
"consistency_type": "crash",
"create_time": "2020-10-25 07:20:00 -0400",
"is_partial": "",
"missing_volumes": [
"name": "volume1",
"name": "string",
"snapmirror_label": "sm_label",
"snapshot_volumes": [
"snapshot": {
"name": "this_snapshot",
"volume": {
"name": "volume1",
"svm": {
"name": "svm1",
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
53411918 |
Snapshot copy operation not permitted. |
53411921 |
Failed to create Snapshot copy for consistency group. |
href |
string |
self_link
consistency_group
name |
string |
The name of the consistency group. |
uuid |
string |
The unique identifier of the consistency group. |
_links
volume_reference
name |
string |
The name of the volume. This field cannot be specified in a POST or PATCH method. |
uuid |
string |
snapshot_reference
name |
string |
uuid |
string |
consistency_group_volume_snapshot
snapshot |
volume |
svm_reference
name |
string |
uuid |
string |
consistency_group_snapshot
comment |
string |
consistency_group |
consistency_type |
string |
create_time |
string |
is_partial |
boolean |
missing_volumes |
name |
string |
snapmirror_label |
string |
snapshot_volumes |
svm |
uuid |
string |
write_fence |
boolean |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
