Evaluation licenses
You can use an evaluation license if you want to evaluate ONTAP Select before making the decision to purchase. The evaluation license is included with the ONTAP Select Deploy administration utility and is automatically applied to each ONTAP Select node as part of an evaluation deployment.
Licensing characteristics
The ONTAP Select evaluation license has the following characteristics:
A production license with storage capacity is not required
The node serial number is twenty digits and automatically generated by ONTAP Select Deploy
(you do not acquire it directly from NetApp)
The evaluation period provided by the license can be up to 90 days
The maximum storage allocated by each node is the same as a production license
Upgrade to a production license
You can upgrade an ONTAP Select evaluation cluster to use a production license. You should be aware of the following restrictions:
You must use the Deploy administration utility to perform the license upgrade
A capacity tier license can be used, however capacity pools licensing is not supported
Each node must have enough storage allocated to support the minimum required for a production license, based on the cluster size
See Convert an evaluation license to a production license for more information.
