ONTAP features
ONTAP Select offers full support for most ONTAP functionality. Many of the ONTAP features are licensed automatically for each node when you deploy a cluster. However some features require a separate license.
ONTAP features that have hardware-specific dependencies are generally not supported with ONTAP Select. |
ONTAP features automatically enabled by default
The following features are included with ONTAP Select and licensed by default:
CIFS
Deduplication and compression
FlexCache
FlexClone
iSCSI
NDMP
NetApp Volume Encryption (non-restricted countries only)
NFS
NVMe over TCP
ONTAP multitenancy capability
ONTAP S3
SnapMirror
SnapRestore
SnapVault
ONTAP features that are separately licensed
You must acquire a separate license for any ONTAP feature that is not enabled by default, including:
Data Availability Service
FabricPool
FlexCache (zero cost)
MetroCluster SDS (ONTAP Select premium license offering)
SnapLock Enterprise (SnapLock Compliance is not supported for ONTAP Select)
SyncMirror (zero cost)
You do not need a FabricPool license when utilizing StorageGRID Webscale. |
