JSON for script to create a cluster
When creating or deleting an ONTAP Select cluster using the Python code samples, you must provide a JSON file as input to the script. You can copy and modify the appropriate JSON sample based on your deployment plans.
Single-node cluster on ESXi
"hosts": [
"password": "mypassword1",
"name": "host-1234",
"type": "ESX",
"username": "admin"
"cluster": {
"dns_info": {
"domains": ["lab1.company-demo.com", "lab2.company-demo.com",
"lab3.company-demo.com", "lab4.company-demo.com"
"dns_ips": ["10.206.80.135", "10.206.80.136"]
"ontap_image_version": "9.7",
"gateway": "10.206.80.1",
"ip": "10.206.80.115",
"name": "mycluster",
"ntp_servers": ["10.206.80.183", "10.206.80.142"],
"ontap_admin_password": "mypassword2",
"netmask": "255.255.254.0"
"nodes": [
"serial_number": "3200000nn",
"ip": "10.206.80.114",
"name": "node-1",
"networks": [
"name": "ontap-external",
"purpose": "mgmt",
"vlan": 1234
"purpose": "data",
"vlan": null
"name": "ontap-internal",
"purpose": "internal",
"vlan": null
"host_name": "host-1234",
"is_storage_efficiency_enabled": false,
"instance_type": "small",
"storage": {
"disk": [],
"pools": [
"name": "storage-pool-1",
"capacity": 4802666790125
Single-node cluster on ESXi using vCenter
"hosts": [
"name":"host-1234",
"type":"ESX",
"mgmt_server":"vcenter-1234"
"cluster": {
"dns_info": {"domains": ["lab1.company-demo.com", "lab2.company-demo.com",
"dns_ips": ["10.206.80.135","10.206.80.136"]
"ontap_image_version":"9.7",
"gateway":"10.206.80.1",
"ip":"10.206.80.115",
"name":"mycluster",
"ntp_servers": ["10.206.80.183","10.206.80.142"],
"ontap_admin_password":"mypassword2",
"netmask":"255.255.254.0"
"vcenter": {
"password":"mypassword2",
"hostname":"vcenter-1234",
"username":"selectadmin"
"nodes": [
"ip":"10.206.80.114",
"name":"node-1",
"networks": [
"name":"ONTAP-Management",
"purpose":"mgmt",
"vlan":null
"name": "ONTAP-External",
"purpose":"data",
"vlan":null
"name": "ONTAP-Internal",
"purpose":"internal",
"vlan":null
"storage": {
"disk":[],
"pools": [
"capacity":5685190380748
Single-node cluster on KVM
"hosts": [
"name":"host-1234",
"type":"KVM",
"username":"root"
"cluster": {
"dns_info": {
"name":"CBF4ED97",
"nodes": [
"serial_number":"3200000nn",
"name": "node-1",
"networks": [
"purpose": "mgmt",
"vlan":1234
"purpose": "data",
"vlan": null
"vlan": null
"storage": {
"disk": [],
"pools": [
