JSON pour permettre la création d'un cluster par script
Contributeurs
Lors de la création ou la suppression d'un cluster ONTAP Select à l'aide d'exemples de code Python, vous devez fournir un fichier JSON en tant qu'entrée du script. Vous pouvez copier et modifier l'exemple JSON approprié en fonction de vos plans de déploiement.
Cluster à un seul nœud sur ESXi
"hosts": [
"password": "mypassword1",
"name": "host-1234",
"type": "ESX",
"username": "admin"
"cluster": {
"dns_info": {
"domains": ["lab1.company-demo.com", "lab2.company-demo.com",
"lab3.company-demo.com", "lab4.company-demo.com"
"dns_ips": ["10.206.80.135", "10.206.80.136"]
"ontap_image_version": "9.7",
"gateway": "10.206.80.1",
"ip": "10.206.80.115",
"name": "mycluster",
"ntp_servers": ["10.206.80.183", "10.206.80.142"],
"ontap_admin_password": "mypassword2",
"netmask": "255.255.254.0"
"nodes": [
"serial_number": "3200000nn",
"ip": "10.206.80.114",
"name": "node-1",
"networks": [
"name": "ontap-external",
"purpose": "mgmt",
"vlan": 1234
"purpose": "data",
"vlan": null
"name": "ontap-internal",
"purpose": "internal",
"vlan": null
"host_name": "host-1234",
"is_storage_efficiency_enabled": false,
"instance_type": "small",
"storage": {
"disk": [],
"pools": [
"name": "storage-pool-1",
"capacity": 4802666790125
Cluster à un seul nœud sur ESXi à l'aide de vCenter
"hosts": [
"name":"host-1234",
"type":"ESX",
"mgmt_server":"vcenter-1234"
"cluster": {
"dns_info": {"domains": ["lab1.company-demo.com", "lab2.company-demo.com",
"dns_ips": ["10.206.80.135","10.206.80.136"]
"ontap_image_version":"9.7",
"gateway":"10.206.80.1",
"ip":"10.206.80.115",
"name":"mycluster",
"ntp_servers": ["10.206.80.183","10.206.80.142"],
"ontap_admin_password":"mypassword2",
"netmask":"255.255.254.0"
"vcenter": {
"password":"mypassword2",
"hostname":"vcenter-1234",
"username":"selectadmin"
"nodes": [
"ip":"10.206.80.114",
"name":"node-1",
"networks": [
"name":"ONTAP-Management",
"purpose":"mgmt",
"vlan":null
"name": "ONTAP-External",
"purpose":"data",
"vlan":null
"name": "ONTAP-Internal",
"purpose":"internal",
"vlan":null
"storage": {
"disk":[],
"pools": [
"capacity":5685190380748
Cluster à un seul nœud sur KVM
"hosts": [
"name":"host-1234",
"type":"KVM",
"username":"root"
"cluster": {
"dns_info": {
"name":"CBF4ED97",
"nodes": [
"serial_number":"3200000nn",
"name": "node-1",
"networks": [
"purpose": "mgmt",
"vlan":1234
"purpose": "data",
"vlan": null
"vlan": null
"storage": {
"disk": [],
"pools": [
