Replace a failed drive when using SW RAID
When a drive using software RAID fails, ONTAP Select assigns a spare drive if one is available and starts the rebuild process automatically. This is similar to how ONTAP works on FAS and AFF. However if no spare drive is available, you need to add one to the ONTAP Select node.
Note Both the removal of the failed drive and the addition of a new drive (marked as a spare) must be performed through ONTAP Select Deploy. Attaching a drive to the ONTAP Select VM using vSphere is not supported.
Identify the failed drive
When a drive fails you need to use the ONTAP CLI to identify the failed disk.
Steps
  1. Sign in to the ONTAP CLI using the administrator account.
  2. Identify the disk drive that failed.
    <cluster name>::> storage disk show -container-type broken
    Usable Disk Container Container
    Disk Size Shelf Bay Type Type Name Owner
    NET-1.4 893.3GB - - SSD broken - sti-rx2540-346a'
Remove the failed drive
After you identify the drive that failed, remove the disk.
Steps
  1. Sign in to the Deploy web user interface using the administrator account.
  2. Click the Clusters tab and select the relevant cluster.
    Node details
  3. Click + to expand the storage view.
    Edit node storage
  4. Click Edit to make changes to the attached disks and uncheck the failed drive.
    Storage disk details
  5. Provide the cluster credentials and click Edit Storage.
    ONTAP credentials
  6. Confirm the operation.
    Warning
Add the new spare drive
After you remove the failed drive, add the spare disk.
Steps
    HA pair
    Edit node storage
  4. Click Edit and confirm that the new drive is available and select it.
