ONTAP Select
Request and response API transaction
Every Deploy API call is performed as an HTTP request to the Deploy virtual machine which generates an associated response to the client. This request/response pair is considered an API transaction. Before using the Deploy API, you should be familiar with the input variables available to control a request and the contents of the response output.
Input variables controlling an API request
You can control how an API call is processed through parameters set in the HTTP request.
Request headers
You must include several headers in the HTTP request, including:
  • content-type
    If the request body includes JSON, this header must be set to application/json.
  • accept
    If the response body will include JSON, this header must be set to application/json.
  • authorization
    Basic authentication must be set with the user name and password encoded in a base64 string.
Request body
The content of the request body varies depending on the specific call. The HTTP request body consists of one of the following:
  • JSON object with input variables (such as, the name of a new cluster)
  • Empty
Filter objects
When issuing an API call that uses GET, you can limit or filter the returned objects based on any attribute. For example, you can specify an exact value to match:
<field>=<query value>
In addition to an exact match, there are other operators available to return a set of objects over a range of values. ONTAP Select supports the filtering operators shown below.
Operator Description
Equal to
Less than
Greater than
Less than or equal to
Greater than or equal to
Or
Not equal to
Greedy wildcard
You can also return a set of objects based on whether a specific field is set or not set by using the null keyword or its negation (!null) as part of the query.
Selecting object fields
By default, issuing an API call using GET returns only the attributes that uniquely identify the object or objects. This minimum set of fields acts as a key for each object and varies based on the object type. You can select additional object properties using the fields query parameter in the following ways:
  • Inexpensive fields
    Specify fields=* to retrieve the object fields that are maintained in local server memory or require little processing to access.
  • Expensive fields
    Specify fields=** to retrieve all the object fields, including those requiring additional server processing to access.
  • Custom field selection
    Use fields=FIELDNAME to specify the exact field you want. When requesting multiple fields, the values must be separated using commas without spaces.
Tip As a best practice, you should always identify the specific fields you want. You should only retrieve the set of inexpensive or expensive fields when needed. The inexpensive and expensive classification is determined by NetApp based on internal performance analysis. The classification for a given field can change at any time.
Sort objects in the output set
The records in a resource collection are returned in the default order defined by the object. You can change the order using the order_by query parameter with the field name and sort direction as follows:
order_by=<field name> asc|desc
For example, you can sort the type field in descending order followed by id in ascending order:
order_by=type desc, id asc
When including multiple parameters, you must separate the fields with a comma.
Pagination
When issuing an API call using GET to access a collection of objects of the same type, all matching objects are returned by default. If needed, you can limit the number of records returned using the max_records query parameter with the request. For example:
max_records=20
If needed, you can combine this parameter with other query parameters to narrow the result set. For example, the following returns up to 10 system events generated after the specified time:
time⇒ 2019-04-04T15:41:29.140265Z&max_records=10
You can issue multiple requests to page through the events (or any object type). Each subsequent API call should use a new time value based on the latest event in the last result set.
Interpret an API response
Each API request generates a response back to the client. You can examine the response to determine
whether it was successful and retrieve additional data as needed.
HTTP status code
The HTTP status codes used by the Deploy REST API are described below.
Code Meaning Description
200
OK
Indicates success for calls that do not create a new object.
201
Created
An object is successfully created; the location response header includes the unique identifier for the object.
202
Accepted
A long-running background job has been started to perform the request, but the operation has not completed yet.
400
Bad request
The request input is not recognized or is inappropriate.
403
Forbidden
Access is denied due to an authorization error.
404
Not found
The resource referred to in the request does not exist.
405
Method not allowed
The HTTP verb in the request is not supported for the resource.
409
Conflict
An attempt to create an object failed because the object already exists.
500
Internal error
A general internal error occurred at the server.
501
Not implemented
The URI is known but is not capable of performing the request.
Response headers
Several headers are included in the HTTP response generated by the Deploy server, including:
  • request-id
    Every successful API request is assigned a unique request identifier.
  • location
    When an object is created, the location header includes the complete URL to the new object including the unique object identifier.
Response body
The content of the response associated with an API request differs based on the object, processing type, and the success or failure of the request. The response body is rendered in JSON.
  • Single object
    A single object can be returned with a set of fields based on the request. For example, you can use GET to retrieve selected properties of a cluster using the unique identifier.
  • Multiple objects
    Multiple objects from a resource collection can be returned. In all cases, there is a consistent format used, with num_records indicating the number of records and records containing an array of the object instances. For example, you can retrieve all the nodes defined in a specific cluster.
  • Job object
    If an API call is processed asynchronously, a Job object is returned which anchors the background task. For example, the POST request used to deploy a cluster is processed asynchronously and returns a Job object.
  • Error object
    If an error occurs, an Error object is always returned. For example, you will receive an error when attempting to create a cluster with a name that already exists.
  • Empty
    In certain cases, no data is returned and the response body is empty. For example, the response body is empty after using DELETE to delete an existing host.
