ONTAP Select
ONTAP Select licenses
There are several related tasks you can perform as part of administering the ONTAP Select licenses.
Manage licenses
You can add, edit, and delete ONTAP Select capacity tier licenses as needed.
Steps
  1. Click ONTAP Select Deploy in the Global Inventory Lists pane.
  2. Click the Administration tab.
  3. Expand the Licenses option and click either Capacity Tier or Capacity Pool to select the license type.
    The current licenses and any issues are displayed.
  4. Optionally, click Filtering and create a filter to limit the licenses that are displayed.
  5. Perform the desired task:
    1. To add a license, click +ADD, click Upload License(s), and select a license file.
    2. To delete an existing license, click the trash can icon to the right of the license.
