Access the ONTAP Select video console
Creating your file...
Your file is ready
You can access the video console of the ESXi virtual machine where ONTAP Select is running.
About this task
You might need to access the virtual machine console to troubleshoot an issue or when asked to do so by NetApp support.
Steps
Access the vSphere client and sign in.
Navigate to the appropriate location in the hierarchy to locate the ONTAP Select virtual machine.
Right click the virtual machine and select Open Console.
