Verify and remove the Deploy vCenter plug-in
You can use the ONTAP Select Deploy web user interface to upgrade or remove the Deploy plug-in from the vCenter server. You can also verify that the plug-in is still installed.
Review Before you begin.
The VMware vCenter plug-in should be installed and registered.
The vCenter administrator account must have the following vCenter privileges:
Extension
Update extension
Unregister extension
Sign in to the Deploy utility using the administrator account.
Click the Administration tab at the top of the page and then click Management Servers in the pane on the left.
Select the target management server and click
and optionally select on of:-
Verify Plugin
Unregister Plugin
Provide the vCenter credentials if prompted.
If you remove the plug-in, you must perform one of the following tasks to complete its removal from the vCenter server:
Reboot the vCenter server
Manually remove the plug-in from the vCenter server
