Overview of storage systems for ONTAP tools
You should add storage systems to ONTAP tools for VMware vSphere and set default credentials, if required, by using the ONTAP tools interface.
ONTAP tools for VMware vSphere provides a single mechanism to discover storage systems and to set the storage credentials. The credentials provide the ONTAP permissions that are required to enable ONTAP tools users to perform tasks by using the storage systems.
Before ONTAP tools can display and manage the storage resources, ONTAP tools must discover the storage systems. As part of the discovery process, you must supply the ONTAP credentials for your storage systems. These are the privileges (or roles) that are associated with the user name and password pair that is assigned to each storage system. These user name and password pairs use ONTAP role-based access control (RBAC) and must be set up from within ONTAP. You cannot change these credentials from within ONTAP tools. You can define ONTAP RBAC roles by using ONTAP System Manager.
If you log in as an administrator, you automatically have all of the privileges for that storage system. |
When you add a storage system to ONTAP tools, you must supply an IP address for the storage system and the user name and password pair that is associated with that system. You can set up default credentials that ONTAP tools will use during the storage system discovery process, or you can manually enter credentials when the storage system is discovered. The details of the storage system that is added to ONTAP tools for VMware vSphere are automatically pushed to the extensions that you enable in your deployment. You do not have to manually add storage to VASA Provider and Storage Replication Adapter (SRA). Both ONTAP tools for VMware vSphere and SRA support the addition of credentials at the cluster level and storage virtual machine (SVM) level. VASA Provider supports only cluster-level credentials for adding storage systems. When you add a storage system any communication between ONTAP tools plug-in and the storage system should be mutually authenticated.
If your environment includes multiple vCenter Server instances, when you add a storage system to ONTAP tools from the Storage Systems page, the Add Storage System dialog box displays a vCenter Server box where you can specify to which vCenter Server instance the storage system is to be added. If you add a storage system by right-clicking a datacenter name, you do not have the option to specify a vCenter Server instance because the server is already associated with that datacenter.
Discovery happens in one of the following ways. In each case, you must supply credentials for any newly discovered storage system.
When the ONTAP tools service starts, ONTAP tools begins its automatic background discovery process.
You can click the REDISCOVER All button in the Storage Systems page, or on a host or datacenter to select it from the Actions menu ( Actions > Netapp ONTAP tools > Update Host and Storage Data ). You can also click DISCOVER on the Getting Started tab of the 'Overview' section.
All of the ONTAP tools features require specific permissions to perform tasks. You can limit what users can do based on the credentials that are associated with the ONTAP role. All of the users that have the same storage system user name and password pair share the same set of storage system credentials and can perform the same operations.
