Cloud Volumes ONTAP
Deployment overview for Cloud Volumes ONTAP in AWS
Contributors netapp-manini netapp-tonias netapp-ahibbard
For deploying Cloud Volumes ONTAP, you first need to know about your AWS subscription and Cloud Volumes ONTAP licenses. You must also verify that you have a NetApp Console agent created for your AWS account. Much of the information in this topic needs to be performed as part of your Console setup before you begin to even deploy Cloud Volumes ONTAP.
You can onboard Cloud Volumes ONTAP in AWS using either the AWS Marketplace or the NetApp Console. The following table provides a high-level overview of the tasks you need to complete to deploy Cloud Volumes ONTAP in AWS.
Note If you subscribe to the Cloud Volumes ONTAP standalone offering in AWS Marketplace, the steps differ. For information about onboarding from AWS Marketplace, see Onboard Cloud Volumes ONTAP standalone offering in AWS Marketplace.
Task Description Reference Notes for private-mode deployments
Create a Console agent
If you don't have a Console agent yet, create one before deploying Cloud Volumes ONTAP. If deploying in a subnet with no internet access, manually install the Console agent and access the NetApp Console running on that agent.
Refer to the Console setup guide:
Create a Console agent in AWS
If deploying in a subnet with no internet access, manually install the Console agent and access the NetApp Console user interface that's running on that Console agent. Refer to the Console setup guide:
Deploy the NetApp Console agent in private mode
Verify NetApp Console roles
After you have created a Console agent, you must verify that the necessary IAM roles and Cloud Volumes ONTAP roles and permissions are in place.
In private mode, the Console agent must have the necessary roles and permissions configured correctly. However, Cloud Volumes ONTAP roles don't apply to private mode deployments. Refer to the Console setup guide: NetApp Console access roles
Plan your configuration
The Console offers preconfigured packages that match your workload requirements, or you can create your own configuration. If you choose your own configuration, you should understand the options available to you.
You need to have similar planning considerations for private-mode deployments.
Set up your networking
  1. Ensure your VPC and subnets support connectivity between the Console agent and Cloud Volumes ONTAP.
  2. Enable outbound internet access for AutoSupport.
  3. Set up a VPC endpoint to Amazon S3 for data tiering. A VPC endpoint is required if you want to tier cold data from Cloud Volumes ONTAP to low-cost object storage.
Outbound internet access for AutoSupport is not required. All other networking requirements remain the same.
Set up the AWS KMS
If you want to use Amazon encryption with Cloud Volumes ONTAP, ensure that an active Customer Master Key (CMK) exists and modify the key policy to add the IAM role for the Console agent as a key user.
Similar steps apply to private-mode deployments.
Deploy Cloud Volumes ONTAP from the Console
When you have performed all prerequisites, you can complete the steps in the wizard to deploy Cloud Volumes ONTAP in AWS.
Private mode supports only advanced deployment. Before beginning the deployment, ensure that you have purchased a Cloud Volumes ONTAP license from NetApp. Private-mode deployments rely on BYOL licenses. Marketplace subscriptions are not supported for charging your Cloud Volumes ONTAP usage. Obtain the license file from NetApp, and upload it during deployment. Refer to:
