Add Annotation dialog box
PDF of this doc site
- Online help
- Monitor and manage cluster performance
- Monitor and manage cluster health
Creating your file...
Your file is ready
The Add Annotation dialog box enables you to create custom annotations that you can associate with clusters, volumes, and storage virtual machines (SVMs) through annotation rules.
You must have the Application Administrator or Storage Administrator role.
Annotation Name
Specifies the name of the annotation. You must enter a unique name for the annotation.
Specifies a meaningful description of the annotation.
Annotation Values
Add
Adds a new value to the selected annotation.
Delete
Deletes the selected value for an annotation.
Command buttons
Save and Close
Saves the new annotation and closes the Add Annotation dialog box dialog box.
Cancel
Closes the Add Annotation dialog box without saving your changes.
