Change the reserved capacity settings for a snapshot volume
- PDF of this doc site
Creating your file...
You can change the settings for a snapshot volume to adjust the percentage point at which the system sends an alert notification when the reserved capacity for a snapshot volume is nearing full.
Select Storage › Pools & Volume Groups.
Click the Reserved Capacity tab.
Select the snapshot volume that you want to edit, and then click View/Edit Settings.
The Snapshot Volume Reserved Capacity Settings dialog box appears.
Change the reserved capacity settings for the snapshot volume as appropriate.
Field Details
Setting Description Alert me when…
Use the spinner box to adjust the percentage point at which the system sends an alert notification when the reserved capacity for a member volume is nearing full.
When the reserved capacity for the snapshot volume exceeds the specified threshold, the system sends an alert, allowing you time to increase reserved capacity or to delete unnecessary objects.
Click Save to apply your changes to the snapshot volume reserved capacity settings.
