Export key management server certificates
- PDF of this doc site
Creating your file...
Your file is ready
You can save a certificate for a key management server to your local machine.
Before you begin
You must be logged in with a user profile that includes Security admin permissions. Otherwise, certificate functions do not appear.
Certificates must be previously imported.
Steps
Select Settings › Certificates.
Select the Key Management tab.
From the table, select the certificate you want to export, and then click Export.
A Save dialog box opens.
Enter a filename and click Save.
