SANtricity 11.5
Functional comparison of pools and volume groups
The function and purpose of a pool and a volume group are the same. Both objects are a set of drives logically grouped together in a storage array and are used to create volumes that a host can access.
The following table helps you decide whether a pool or volume group best suits your storage needs.
Function Pool Volume Group
Different RAID level supported
No. Always RAID 6.
Yes. RAID 0, 1, 10, 5, and 6 available.
Thin volumes supported
Yes
No
Full disk encryption (FDE) supported
Yes
Yes
Data Assurance (DA) supported
Yes
Yes
Shelf loss protection supported
Yes
Yes
Drawer loss protection supported
Yes
Yes
Mixed drive speeds supported
Recommended to be the same, but not required. Slowest drive determines speed for all drives.
Mixed drive capacity supported
Recommended to be the same, but not required. Smallest drive determines capacity for all drives.
Minimum number of drives
11
Depends on RAID level. RAID 0 needs 1. RAID 1 or 10 needs 2 (requires an even number). RAID 5 minimum is 3. RAID 6 minimum is 5.
Maximum number of drives
Up to the maximum limit for the storage array
RAID 1 and 10—​up to the maximum limit of the storage array RAID 5, 6—​30 drives
Can choose individual drives when creating a volume
No
Yes
Can specify segment size when creating a volume
Yes. 128K supported.
Yes
Can specify I/O characteristics when creating a volume
No
Yes. File system, database, multimedia, and custom supported.
Drive failure protection
Uses preservation capacity on each drive in the pool making reconstruction faster.
Uses a hot spare drive. Reconstruction is limited by the IOPs of the drive.
Warning when reaching capacity limit
Yes. Can set an alert when used capacity reaches a percentage of the maximum capacity.
No
Migration to a different storage array supported
No. Requires that you migrate to a volume group first.
Yes
Dynamic Segment Size (DSS)
No
Yes
Can change RAID level
No
Yes
Volume expansion (increase capacity)
Yes
Yes
Capacity expansion (add capacity)
Yes
Yes
Capacity reduction
Yes
No
Note
Mixed drive types (HDD, SSD) are not supported for either pools or volume groups.
