Astra Automation
Retrieve a namespace for a cloud
Colaboradores
GET /accounts/{account_id}/topology/v1/clouds/{cloud_id}/clusters/{cluster_id}/namespaces/{namespace_id}
Returns the stored Namespace API resource in the JSON response body.
account_id
string
path
True
  • example: {{.Account}}
cloud_id
string
path
True
ID of the containing cloud resource
cluster_id
string
path
True
ID of the containing cluster resource
namespace_id
string
path
True
ID of the namespace collection to list
Status: 200, Returns the stored Namespace API resource in the JSON response body.
type
string
True
  • "application/astra-namespace"
version
string
True
  • "1.0"
  • "1.1"
id
string
True
name
string
True
JSON string containing a value indicating the name of the namespace. Defined values are:
  • Minimum length: 1
  • Maximum length: 255
namespaceState
string
True
JSON string containing a value indicating the state of the namespace. Defined values are:
  • "discovered" - The namespace has been found in the cluster
  • "removed" - The namespace has been deleted from the cluster, or the cluster is not managed but there might be resources referring to the namespace
namespaceStateDetails
array[type_astra_stateDetails]
True
JSON array of JSON objects that lists additional details about why "state" transitioned into "state a", "state b", or "state c". If no details are available, this array will be empty. Defined values are:
  • Minimum items: 0
kubernetesLabels
array[type_astra_label]
False
JSON array of JSON objects, each containing a Kubernetes label associated with the namespace. Defined values are:
  • Conforms to the Kubernetes Label Array Schema
clusterID
string
True
JSON string containing a globally unique identifier of the cluster that the namespace is contained in. Defined values are:
  • Conforms to the Astra Identifier Schema
systemType
string
False
JSON string that denotes that the namespace is a type of system namespace. This field identifies what type of system namespace, if any, the namespace is (version 1.1 only). Defined values are:
  • "kubernetes" - A generic Kubernetes (K8s) system namespace, for example, "kube-system"
  • "netapp" - A NetApp system namespace, for example, "trident" or "netapp-monitoring"
  • "openshift" - An OpenShift system namespace, for example, "openshift-monitoring"
  • "rke" - A Rancher namespace, for example, "cattle-logging"
  • "other" - Common system namespaces that don't necessarily fit elsewhere, for example, "ingress-nginx", "tekton-system"
links
array[links]
True
JSON array of JSON objects, each indicating a link relationship associated with the resource. Defined values are:
  • Minimum items: 2
metadata
type_astra_metadata
True
  • Conforms to the Astra Metadata Schema
  "type": "application/astra-namespace",
  "version": "1.1",
  "id": "2de811a6-ce8f-512c-9c3a-9585ca66de22",
  "name": "kube-system",
  "namespaceState": "discovered",
  "namespaceStateDetails": [
      "type": "https://astra.netapp.io/stateDetails/9",
      "title": "Namespace Discovered",
      "detail": "The namespace was discovered in the indicated managed cluster"
  "kubernetesLabels": [
      "name": "app.kubernetes.io/environment",
      "value": "dev"
  "clusterID": "0f284377-e5dc-4dcd-bacd-3197f2b8a347",
  "systemType": "kubernetes",
  "links": [
      "rel": "canonical",
      "href": "https://www.astra.io/accounts/0b311ae7-d89a-4a11-a52c-1349ca090415/topology/v1/namespaces/7d451d2f-196e-4234-aee9-7e2376047e63"
      "rel": "collection",
      "href": "https://www.astra.io/accounts/0b311ae7-d89a-4a11-a52c-1349ca090415/topology/v1/clouds/e0490197-872e-4de8-9287-b04a938e801f/clusters/0f284377-e5dc-4dcd-bacd-3197f2b8a347/namespaces"
  "metadata": {
    "labels": [],
JSON
Status: 401, Unauthorized
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "401"
JSON
Status: 400, Bad request
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
invalidParams
array[invalidParams]
False
List of invalid query parameters
  "status": "400"
JSON
Status: 403, Forbidden
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
  "status": "403"
JSON
Status: 404, Not found
type
string
True
title
string
True
detail
string
False
status
string
True
correlationID
string
False
Example error response
  "status": "404"
JSON
type
string
True
title
string
True
detail
string
True
type_astra_label
name
string
True
value
string
True
rel
string
True
JSON string containing the type of relation that the link indicates. Defined values are:
  • "canonical" - The preferred link for accessing the resource
  • "collection" - The collection that the resource belongs to
string
True
JSON string containing the link. Defined values are:
type_astra_metadata
labels
True
creationTimestamp
string
True
string
True
createdBy
string
True
modifiedBy
string
False
invalidParams
name
string
True
reason
string
True
