Cloud Tiering APIs
The Cloud Tiering capabilities that are available through the web UI are also available through GraphQL APIs.
Getting started
To get started, obtain a user token and then add the token to the Authorization header when making API calls.
Steps
Click Learn how to authenticate.
Follow the instructions to acquire and use an access token.
API reference
Documentation for each API is available from NetApp Cloud Central.
