Reset the default configuration on the new nodes
Contributors netapp-pcarriga
To confirm that configuration information on the boot media does not interfere with the controller upgrade, you must reset the configurations of node3 and node4 to the default configuration settings.
About this task
You must perform the following steps on node3 and node4. You can perform the steps on each node in parallel.
  1. Boot the node into the boot menu:
    boot_ontap menu
  2. At the boot menu prompt, type wipeconfig and then select Enter.
    You see the following output:
    Please choose one of the following:
        (1) Normal Boot.
        (2) Boot without /etc/rc.
        (3) Change password.
        (4) Clean configuration and initialize all disks.
        (5) Maintenance mode boot.
        (6) Update flash from backup config.
        (7) Install new software first.
        (8) Reboot node.
        (9) Configure Advanced Drive Partitioning.
        Selection (1-9)?  wipeconfig
  3. Enter yes when you see a prompt similar to the following:
    This option deletes critical system configuration, including cluster membership.
    Warning: do not run this option on a HA node that has been taken over.
    Are you sure you want to continue?: yes
    Rebooting to finish wipeconfig request.
    The system initiates the wipeconfig procedure and reboots. When the procedure is complete, the system returns to the boot menu.
  4. From the boot menu, enter 8 to reboot the node, and enter Ctrl-C during AUTOBOOT to stop the node at the LOADER prompt.
What's next?
After resetting the default configuration on the new nodes, install the new nodes.
