Associate storage backend with vCenter
vCenter listing page shows the associated number of storage backends. Each vCenter has option to Associate a storage backend
About this task
This task help you to create mapping between storage backend and onboarded vCenter globally.
Steps
Launch
https://loadBalanceIP:8443/virtualization/ui/from browser with ONTAP tools administrator credentials provided during deployment. -
Select vCenters from the sidebar.
Click on the vertical ellipsis against the vCenter that you want to associate with storage backends.
Select storage backend from the dropdown in the pop up.
Select Associate Storage Backend option to associate vCenter with the required storage backend.
