Generate Reports
In SaaS Backup Partner Central, you can generate reports for license usage, storage usage, job statistics, activity, audits, and renewals.
Steps
From the dashboard, click Reports on the left.
Select the category for which you want to generate a report.
License Usage
Storage Usage
Job Statistics
Activity Report
Audit Report
Renewal Report
Click Generate under the category.
Reports are generated in CSV format.
