Manage Keys
You can add and manage keys for enhanced security in Partner Central from the Key Management setting.
Add keys
Steps
From the dashboard, click
Select Key Management from the dropdown menu.
To add a key, click
In Add Key, do the following:
Select the user.
Add a description.
Select expiry.
Click Add.
A box appears with the message “Successfully generated the key.”
Click
to show the unencrypted key and click
to hide the unencrypted key.
