Astra Trident
FSx for ONTAP configuration options and examples
Contributors netapp-aruldeepa netapp-revathid
Learn about backend configuration options for Amazon FSx for ONTAP. This section provides backend configuration examples.
Backend configuration options
See the following table for the backend configuration options:
Parameter Description Example
version
Always 1
storageDriverName
Name of the storage driver
ontap-nas, ontap-nas-economy, ontap-nas-flexgroup, ontap-san, ontap-san-economy
backendName
Custom name or the storage backend
Driver name + “_” + dataLIF
managementLIF
IP address of a cluster or SVM management LIF
A fully-qualified domain name (FQDN) can be specified.
Can be set to use IPv6 addresses if Astra Trident was installed using the IPv6 flag. IPv6 addresses must be defined in square brackets, such as [28e8:d9fb:a825:b7bf:69a8:d02f:9e7b:3555].
“10.0.0.1”, “[2001:1234:abcd::fefe]”
dataLIF
IP address of protocol LIF.
ONTAP NAS drivers: We recommend specifying dataLIF. If not provided, Astra Trident fetches data LIFs from the SVM. You can specify a fully-qualified domain name (FQDN) to be used for the NFS mount operations, allowing you to create a round-robin DNS to load-balance across multiple data LIFs. Can be changed after initial setting. Refer to Update dataLIF after initial configuration.
ONTAP SAN drivers: Do not specify for iSCSI. Astra Trident uses ONTAP Selective LUN Map to discover the iSCI LIFs needed to establish a multi path session. A warning is generated if dataLIF is explicitly defined.
autoExportPolicy
Enable automatic export policy creation and updating [Boolean].
Using the autoExportPolicy and autoExportCIDRs options, Astra Trident can manage export policies automatically.
false
autoExportCIDRs
List of CIDRs to filter Kubernetes' node IPs against when autoExportPolicy is enabled.
"[“0.0.0.0/0”, “::/0”]"
labels
Set of arbitrary JSON-formatted labels to apply on volumes
clientCertificate
Base64-encoded value of client certificate. Used for certificate-based auth
clientPrivateKey
Base64-encoded value of client private key. Used for certificate-based auth
trustedCACertificate
Base64-encoded value of trusted CA certificate. Optional. Used for certificate-based authentication.
username
Username to connect to the cluster or SVM. Used for credential-based authentication. For example, vsadmin.
password
Password to connect to the cluster or SVM. Used for credential-based authentication.
svm
Storage virtual machine to use
Derived if an SVM managementLIF is specified.
storagePrefix
Prefix used when provisioning new volumes in the SVM.
Cannot be modified after creation. To update this parameter, you will need to create a new backend.
trident
limitAggregateUsage
Do not specify for Amazon FSx for NetApp ONTAP.
The provided fsxadmin and vsadmin do not contain the permissions required to retrieve aggregate usage and limit it using Astra Trident.
Do not use.
limitVolumeSize
Fail provisioning if requested volume size is above this value.
Also restricts the maximum size of the volumes it manages for qtrees and LUNs, and the qtreesPerFlexvol option allows customizing the maximum number of qtrees per FlexVol.
“” (not enforced by default)
lunsPerFlexvol
Maximum LUNs per Flexvol, must be in range [50, 200].
SAN only.
100
debugTraceFlags
Debug flags to use when troubleshooting. Example, {“api”:false, “method”:true}
Do not use debugTraceFlags unless you are troubleshooting and require a detailed log dump.
null
nfsMountOptions
Comma-separated list of NFS mount options.
The mount options for Kubernetes-persistent volumes are normally specified in storage classes, but if no mount options are specified in a storage class, Astra Trident will fall back to using the mount options specified in the storage backend's configuration file.
If no mount options are specified in the storage class or the configuration file, Astra Trident will not set any mount options on an associated persistent volume.
nasType
Configure NFS or SMB volumes creation.
Options are nfs, smb, or null.
Must set to smb for SMB volumes. Setting to null defaults to NFS volumes.
nfs
qtreesPerFlexvol
Maximum Qtrees per FlexVol, must be in range [50, 300]
200
smbShare
You can specify one of the following: the name of an SMB share created using the Microsoft Management Console or ONTAP CLI or a name to allow Astra Trident to create the SMB share.
This parameter is required for Amazon FSx for ONTAP backends.
smb-share
useREST
Boolean parameter to use ONTAP REST APIs.
useREST When set to true, Astra Trident will use ONTAP REST APIs to communicate with the backend; when set to false, Astra Trident will use ONTAP ZAPI calls to communicate with the backend. This feature requires ONTAP 9.11.1 and later. In addition, the ONTAP login role used must have access to the ontap application. This is satisfied by the pre-defined vsadmin and cluster-admin roles.
Beginning with the Astra Trident 24.06 release and ONTAP 9.15.1 or later, useREST is set to true by default; change useREST to false to use ONTAP ZAPI calls.
true for ONTAP 9.15.1 or later, otherwise false.
aws
You can specify the following in the configuration file for AWS FSx for ONTAP:
- fsxFilesystemID: Specify the ID of the AWS FSx file system.
- apiRegion: AWS API region name.
- apikey: AWS API key.
- secretKey: AWS secret key.
credentials
Specify the FSx SVM credentials to store in AWS Secret Manager.
- name: Amazon Resource Name (ARN) of the secret, which contains the credentials of SVM.
- type: Set to awsarn.
Refer to Create an AWS Secrets Manager secret for more information.
You can change the data LIF after initial configuration by running the following command to provide the new backend JSON file with updated data LIF.
tridentctl update backend <backend-name> -f <path-to-backend-json-file-with-updated-dataLIF>
Note If PVCs are attached to one or multiple pods, you must bring down all corresponding pods and then bring them back up in order to for the new data LIF to take effect.
Backend configuration options for provisioning volumes
You can control default provisioning using these options in the defaults section of the configuration. For an example, see the configuration examples below.
Parameter Description Default
spaceAllocation
Space-allocation for LUNs
true
spaceReserve
Space reservation mode; “none” (thin) or “volume” (thick)
none
snapshotPolicy
Snapshot policy to use
none
qosPolicy
QoS policy group to assign for volumes created. Choose one of qosPolicy or adaptiveQosPolicy per storage pool or backend.
Using QoS policy groups with Astra Trident requires ONTAP 9.8 or later.
We recommend using a non-shared QoS policy group and ensuring the policy group is applied to each constituent individually. A shared QoS policy group will enforce the ceiling for the total throughput of all workloads.
adaptiveQosPolicy
Adaptive QoS policy group to assign for volumes created. Choose one of qosPolicy or adaptiveQosPolicy per storage pool or backend.
Not supported by ontap-nas-economy.
snapshotReserve
Percentage of volume reserved for snapshots “0”
If snapshotPolicy is none, else “”
splitOnClone
Split a clone from its parent upon creation
false
encryption
Enable NetApp Volume Encryption (NVE) on the new volume; defaults to false. NVE must be licensed and enabled on the cluster to use this option.
If NAE is enabled on the backend, any volume provisioned in Astra Trident will be NAE enabled.
For more information, refer to: How Astra Trident works with NVE and NAE.
false
luksEncryption
Enable LUKS encryption. Refer to Use Linux Unified Key Setup (LUKS).
SAN only.
tieringPolicy
Tiering policy to use none
snapshot-only for pre-ONTAP 9.5 SVM-DR configuration
unixPermissions
Mode for new volumes.
Leave empty for SMB volumes.
securityStyle
Security style for new volumes.
NFS supports mixed and unix security styles.
SMB supports mixed and ntfs security styles.
NFS default is unix.
SMB default is ntfs.
Example configurations
Configuration of storage class for SMB volumes
Using nasType, node-stage-secret-name, and node-stage-secret-namespace, you can specify an SMB volume and provide the required Active Directory credentials. SMB volumes are supported using the ontap-nas driver only.
apiVersion: storage.k8s.io/v1
kind: StorageClass
metadata:
parameters:
  backendType: "ontap-nas"
  trident.netapp.io/nasType: "smb"
  csi.storage.k8s.io/node-stage-secret-name: "smbcreds"
  csi.storage.k8s.io/node-stage-secret-namespace: "default"
Configuration for AWS FSx for ONTAP with secret manager
kind: TridentBackendConfig
metadata:
spec:
  version: 1
  storageDriverName: ontap-nas
  backendName: tbc-ontap-nas
  svm: svm-name
  aws:
    fsxFilesystemID: fs-xxxxxxxxxx
  managementLIF:
  credentials:
    type: awsarn
