Edit Annotation dialog box
PDF of this doc site
- Install Unified Manager
- Online Help
- Monitor and manage cluster performance
Creating your file...
Your file is ready
The Edit Annotation dialog box enables you to change the description of an existing annotation.
You must have the OnCommand Administrator or Storage Administrator role.
Annotation Name
Displays the name of the annotation. This field cannot be edited.
Provides a meaningful description of the annotation. You can edit this field when you want to change the current description of the annotation.
Command buttons
Save and Close
Saves the annotation description changes and closes the dialog box.
Cancel
Closes the Edit Annotation dialog box without saving your changes.
