Edit Group Rule dialog box
PDF of this doc site
- Install Unified Manager
- Online Help
- Monitor and manage cluster performance
Creating your file...
Your file is ready
You can edit the group rules you created to include the maximum number of storage objects in a group.
You must have the OnCommand Administrator or Storage Administrator role.
Rule Name
Displays the name of the rule.
Target Object Type
Displays the storage object to be added to a selected group. You cannot change the object type.
Associated Group
Displays the associated group. You can select a different group for the group rule.
Condition
Displays the list of conditions for a selected group. You can edit the conditions. The storage objects are either removed or added to a selected group based on the changes.
Command buttons
Save
Saves the changes you made and closes the dialog box.
Cancel
Closes the Edit Group Rule dialog box without saving your changes.
