OnCommand Unified Manager 9.5
Edit SVM with Infinite Volume Thresholds dialog box
Contributors netapp-adityaw
You can use the Edit SVM with Infinite Volume Thresholds dialog box to modify the default threshold values of each SVM with Infinite Volume, based on your organization's requirements. The default threshold values indicate the level of activity that must be reached on the SVM before an event is triggered.
Capacity
The Capacity area enables you to set capacity threshold conditions for the selected SVM with Infinite Volume:
  • Space Nearly Full
    Specifies the percentage at which the SVM with Infinite Volume is considered to be nearly full. It also displays the corresponding space (in GB, MB, or TB) in the Infinite Volume. For example, if you have an Infinite Volume of size 10 GB, and the Space Nearly Full threshold is 80%, then the following information is displayed: (8 GB of 10 GB).
    You can also use the slider to set the threshold value.
  • Space Full
    Specifies the percentage at which the SVM with Infinite Volume is considered full. It also displays the corresponding space (in GB, MB, or TB) in the Infinite Volume. For example, if you have an Infinite Volume of size 10 GB, and the Space Full threshold is 90%, then the following information is displayed: (9 GB of 10 GB).
  • Snapshot Usage Limit
    Specifies the limit, in percentage, of space reserved for Snapshot copies in the Infinite Volume.
Command buttons
The command buttons enable you to perform the following tasks:
  • Restore to Global Defaults
    Enables you to restore the threshold settings to the current values that are set at the global level.
  • Save
    Saves all the threshold settings.
  • Save and Close
    Saves all the threshold settings and then closes the Edit SVM with Infinite Volume Thresholds dialog box.
  • Cancel
    Ignores any changes to the threshold settings and closes the Edit SVM with Infinite Volume Thresholds dialog box.
