Edit Cluster dialog box
PDF of this doc site
- Install Unified Manager
- Online Help
- Monitor and manage cluster performance
Creating your file...
The Edit Cluster dialog box enables you to modify the connection settings of an existing cluster, including the IP address, port, and protocol.
You can edit the following fields:
Host Name or IP Address
Enables you to specify the FQDN, short name, or the IP address (IPv4 or IPv6) of the cluster-management LIF that is used to connect to the cluster.
User Name
Enables you to specify a user name that can be used to log in to the cluster.
Password
Enables you to specify a password for the specified user name.
Protocol
Enables you to specify the type of protocol that can be configured on the cluster. You can enable HTTP or HTTPS (for a secure connection). Connection is established with the cluster by using both protocols and HTTPS is chosen over HTTP. By default, HTTPS is enabled with the default port 443.
Port
Enables you to specify the port number used to connect to the cluster. If the port is not specified, the default port for the selected protocol is used (80 for HTTP or 443 for HTTPS).
