API reference
The API reference contains details about the ONTAP REST API calls, including the HTTP methods, input parameters, and responses. This complete reference is helpful when developing automation applications using the REST API.
You can access the REST API reference documentation at one of several sites based on the ONTAP release. A copy of the equivalent documentation is also available through the Swagger UI at your local ONTAP system. |
Access the ONTAP API reference documentation online
You can access a copy of the ONTAP REST API reference documentation through the links provided below. The documentation is maintained by ONTAP release.
Access the ONTAP API reference documentation through the Swagger UI
You can access the ONTAP REST API documentation through the Swagger UI at your local ONTAP system.
You must have the following:
IP address or host name of the ONTAP cluster management LIF
User name and password for an account with authority to access the ONTAP REST API
Type the URL in your browser and press Enter:
Sign in using the ONTAP account.
The ONTAP API documentation page is displayed with the API calls organized in major resource categories at the bottom.
As an example of an individual API call, scroll down to the cluster category and click GET /cluster.
