Quick start
Get started quickly by following these steps.
![One](https://raw.githubusercontent.com/NetAppDocs/common/main/media/number-1.png)
Operating System:
RHEL 7.6 or later
RHEL 8.1 or later for SAP-HANA SPS07
SLES 12 SP5 or later and 15 SPX platforms certified by SAP HANA
NetApp Cloud Storage: Azure NetApp Files
Storage layouts: For data and log files, Azure supports only NFSv4.1.
Database layouts:
SAP HANA Multitenant Database Container (MDC) 2.0SPS5, 2.0SPS6, 2.0SPS7 with single or multiple tenants
SAP HANA single host system, SAP HANA multiple host system, HANA System Replication
SAP HANA plug-in on the database host
![Two](https://raw.githubusercontent.com/NetAppDocs/common/main/media/number-2.png)
BlueXP is accessible from a web-based console. When you get started with BlueXP, your first step is to sign up using your existing NetApp Support Site credentials or by creating a NetApp cloud login. For information, refer to Sign up to BlueXP.
![Three](https://raw.githubusercontent.com/NetAppDocs/common/main/media/number-3.png)
After you sign up to BlueXP, you can log in from the web-based console. For information, refer to Log into BlueXP.
![Four](https://raw.githubusercontent.com/NetAppDocs/common/main/media/number-4.png)
You can administer your account by managing users, service accounts, workspaces, and Connectors. For information, refer to Manage your BlueXP account.
